How come?
Old 01-04-2009 | 08:58 PM
Default How come?
How come merc put crane gold rockers under the old valve covers, but when I try to take those valve covers and put them over my own engines they don't clear?
Does Merc have a majic wand or what?
I am sure I am just missing something easy.
jeff1000man is offline
Old 01-04-2009 | 10:34 PM
Wink
I have a stock engine your valve covers would probably fit on, I would be more than happy to trade you engines' so your valve covers will fit
FlyinZX14 is offline
Old 01-04-2009 | 10:39 PM
Arent some of the rockers rounded off?
TxHawk is offline
Old 01-04-2009 | 10:42 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Yep, forget which ones are though. I think it's on 4 of them. They have 1 of the corners ground down on each to clear the bolt hold down recesses.
US1 Fountain is offline
Old 01-04-2009 | 11:08 PM
I have those. I was actually thinking that, I think I just have them out of sequence.
Old 01-04-2009 | 11:26 PM
Rookie's Avatar
intake rocker on #1 and intake rocker on #8.
Just as a side note when you grind new ones do not grind it all at once, take a little off at a time and let it cool it in between. It will create enough heat just by grinding that it will crack along where the pin that holds the roller bearing in. Don't ask me how I know.
Rookie is offline
Old 01-05-2009 | 04:28 AM
Yes Merc did grind down a corner on a few rockers..... In the process of my current rebuild on my 575sci's I sent Crane Cams my rockers to match up two sets and the rockers they sent me have a contour built in to them now so they don't even need to be ground........ I will try to get a pic and part number of the new ones...
Here's Johnny is offline
Old 01-05-2009 | 09:15 AM
I allways wondered what those were ground off for. I have never used those stock covers, so I hever woried about that sequence. I just have to re arrange the sequence.
