-   -   New Throttlebody for 500 and 525 (https://www.offshoreonly.com/forums/general-boating-discussion/201811-new-throttlebody-500-525-a.html)
TylerCrockett 01-19-2009 10:21 PM
This is the new throttlebody we made and tested for the 500 and 525 engine. The engine in the video is a 500 Mercury with 250 hours. We put a set of Dart 310 heads right out of the box No Porting and a Crane 741 cam. We made 575 HP with the stock throttlebody. We then installed the new throttlebody and made 605 HP. The new throttlebody flows about 2000cfm. We made a iac adapter to mount on the front block off plate but the adapter will bolt right on the back of a 525 manifold. It also gained 30 ft #'s of torque thru out the rpm range. http://www.youtube.com/watch?v=kT8FmzMo2Uw
BAJA WILL 01-19-2009 10:23 PM
Nice, now that is some bolt on performance.:drink:
dreamer 01-19-2009 10:37 PM
525 gains?
dreamer 01-20-2009 09:28 AM
500 gains with out the heads and cam? will it give a 30 hp diff on a stock motor?
Dock Holiday 01-20-2009 10:07 AM
Tyler that is awesome and a great package that I had good experience with on the 500's.
The throttle body really looks strange I guess that is called "Thinking Out Of The Box".
Nice job and it's nice to see folks developing products that really work.
Good luck
suntimes 01-20-2009 04:06 PM
Looks interesting--how much extra height is required over a stock 525?
tomcat 01-20-2009 04:25 PM
Good job Tyler! Now make one with four holes over the whole plenum.:D
Wahoo ATV 01-20-2009 06:25 PM
It added 30 hp and 30 torque to my stock 525.
Velocity Tom 01-20-2009 06:45 PM
How much? I need 2.
TylerCrockett 01-21-2009 06:24 AM
We gained 22HP on a stock engine. It really helps when you got full ported heads and a bigger cam when you can't move enough air thru the front of the manifold.
