496 Head bolts
Old 01-31-2009 | 12:23 PM
Default 496 Head bolts
Need torque specs for a 496 head bolts . thanks Jeff
Jeff P31 is offline
Old 01-31-2009 | 07:53 PM
Torque head bolts in three steps, following the torque sequence.
First step, 22ftlbs, Second step, 120 degrees, Final step, 30 degrees on short ones and 60 degrees on medium and long ones.
Raylar recomends 60 ftlbs and that's what I've used last couple times with no problems. Snap-On has that grey handled torque wrench that does the angle setting or aka what I was speaking of in degrees... The above paragrah is right out of the factory manual (not Clymer and the like).
DO NOT re-use the stock bolts. They are torque-to-yield and they are not considered resuable. You can do it but keep in mind they're not the same as they were when new. I recomend buying some good arp's cause they're roughly same price and you can reuse them. Factory bolts are like ten bucks each without any friend discount!!!
SDFever is offline
Old 02-01-2009 | 03:20 PM
Thanks for the info . I guess the old way was to easy so somebody had to change it. Thanks again Jeff
Jeff P31 is offline
Ken N
8
09-24-2008 02:35 PM
alecsammy
4
11-11-2006 02:32 PM
speedball
5
05-28-2004 12:28 AM
convincor
6
05-27-2003 02:45 AM
DanB
5
12-15-2002 05:44 AM
