-   -   Closed Cooling (https://www.offshoreonly.com/forums/general-boating-discussion/204044-closed-cooling.html)
boatfreak 03-01-2009 08:21 AM
Closed Cooling
Tell me a little about it. Do they make an exchanger that can handle a 750hp NA engine? Can you mount the exchanger off to the side? Does anyone have a pic?
Uncle Dave 03-01-2009 08:59 AM
1 Attachment(s)
Sure.
Sen-Dure makes all size heat exchangers and their product is standard on the Ilmor line of engines from 525-725 now.
http://www.sen-dure.com/
Here is a pict.
Uncle Dave
boatfreak 03-01-2009 07:15 PM
Thanks What about the exchanger, can it be mounted off to the side?
Thunderstruck 03-01-2009 07:18 PM
I mounted my exchangers outboard of the engines on L Brackets that attached to the outermost stringers port and stbd. I will try to take a pic. I got good pricing from SeaKamp for the exchangers. My motors run 130-150 with no TSTATS with 600 hp each side. I bought the biggest off the shelf exchanger they had.
Uncle Dave 03-01-2009 07:47 PM
You can mount them just about anywhere as long as you bleed the air out correctly.
Uncle Dave
Tim Bullen 03-06-2009 09:21 PM
I have two custom engineered sets. The heat exchanger would mount remotlely and the smaller expantion tank up higher. These were engineered and built for 800+ hp by Orca Marine. I still have the shop drawings for them. They have been used only one time. I am selling complete with stringer mounts and all stainless hardware and tees. Let me know if you are interested. [email protected]
2112 03-06-2009 10:58 PM
These guys build Teagues heat exchangers
3 Attachment(s)
http://www.aihti.com/
Yes they have something to handle over 800hp and yes they can be mounted to the side.
Don't forget to mount an overflow reservoir at the highest point. :drink:
Uncle Dave 03-06-2009 11:08 PM
Sanitary setup. Good enough for Bob Teague good enough for me.
Uncle Dave
