Battery Chargers / Recomendations >
Old 04-07-2009 | 11:05 AM
Default Battery Chargers / Recomendations
I'm looking for some feed back and experience with battery chargers - I'm torn between the Guest 2631 and the Pro-Pak 4 -Does anyone have any experience on either one of these units?
Much appreciated...
whtnordic is offline
Old 04-07-2009 | 12:55 PM
Strip Poker 388's Avatar
Rob
Sorry no experience with those name brands. My boat came with a C Charles,I had a problem"Fire" and they warranted it,I also have one in my car trailer it stays on 24/7.Even with the prob I would consider buying another.
http://www.offshoreonly.com/forums/g...rger-fire.html
Firefirefire
Strip Poker 388 is offline
Old 04-07-2009 | 01:24 PM
FREEZE FRAME VIDEO's Avatar
freezeframevideo.net
Active Streak: 30 Days
Commercial Members
Default charges
Much appreciated...
I Have Use The Guest Charges For Years Just Put another On in My 30 ' Superboat Never Had A Problem With One 15amp Next To The Tab Motor Jeff
FREEZE FRAME VIDEO is offline
Old 04-07-2009 | 03:26 PM
glassdave's Avatar
Neno the mind boggler
Firefirefire
I have gone through two of the exact same chargers on the Donzi. First one had very little use and was replaced under Z care second also went bad. Luckily not like yours but i dont trust them anymore, get something else.
08 OPA High Points Champion
glassdave is offline
Old 04-07-2009 | 11:50 PM
Are you serious about them catching on fire? - What was the cause?
Thanks for the heads up.....
Old 04-10-2009 | 12:42 AM
Rob
They said it have a defective braze on the circuit board, and they already new about it, no recall,claimed it wasn't bad enough to catch the boat on fire,[what about gas fumes?]
I believe it was a 99 year model. the took the old one back and sent out a reman one,5 year warranty was nice.It did throw the breaker,after I saw it was smoked, I plug it back up thats when the fire started. I guess it would matter how ya had it mounted, the top were the fan is ,it would have to be mounted close to something above it, Member LMarth had the same thing happen to him.
The bad thing was I had just covered up the boat,was fixing to leave and smelled electrical burn,figured it might be something else, until the smoke started coming out from under the cover, prob lucky
