Raw water pump on 496, how long? >
Old 05-28-2009, 09:37 PM
noyzee's Avatar
i ended up doing it. took me about an hour, pretty sure now that i know how to do it i will do it every season, the old one was all dry rot and looked pretty bad.
pretty sure i could do it in under an hour now, atleast on my boat as the seat back lifts up and makes more room and easy to work on
noyzee is offline
Old 05-29-2009, 09:11 AM
Registered User
Shanghied Again's Avatar
I changed both of mine last year and lost one memorial day weekend. This is the first year i didn't change them "Shame on Me! so I will be replacing both.. It is not worth the aggravation when you overheat and have to idle for hours to get in because of a rubber impeller.
Shanghied Again is offline
Old 05-29-2009, 09:28 AM
noyzee's Avatar
thats what im talking about. for the 60 bucks and 2 hours, its worth it
noyzee is offline
Old 05-29-2009, 10:33 AM
NoQuarter
My 496 had 200 hours on the original impeller when I got the boat and it blew. The rubber of the impeller was super hard and not flexible. The pump also was significantly scored. The scoring could cause a new impeller to cavitate and reduce pressure. New pump is expensive. I bought the R&R rebuild kit ($150). Really nice kit and easy to do. The wear plates are stainless and can be flipped over and re-used if they get scored.
Attached Thumbnails Raw water pump on 496, how long?-dscn0367resized.jpg   Raw water pump on 496, how long?-damaged-cup.jpg   Raw water pump on 496, how long?-damaged-cover.jpg
Raw water pump on 496, how long?-kit1.jpg   Raw water pump on 496, how long?-completed-pump.jpg
Old 05-29-2009, 10:36 AM
noyzee's Avatar
that sucks. i h=guess another good reason to swap them each year
noyzee is offline
