Dire Help Needed!!??
Old 05-05-2009 | 09:52 AM
ive got a 1982 wellcraft nova 230 with a 260 merc in it and i bought the boat with no prop, i had one lying around it a 14" 19p 4 blade quicksilver and im getting no out of the whole and i cant get the boat over 4200 RPM. I see there is ALOT of smart people on here so im really hoping someone can help me out with my predicament. THANKS to any and all answers
boatbully is offline
Old 05-05-2009 | 10:14 AM
Wobble's Avatar
SORE MEMBER
Quick and cheap fix would be taking it to a local prop shop and getting it cut down. Tell them your current rpm and your target rpm they should be able to get you close, that should help with your hole shot also.
Wobble is offline
Old 05-05-2009 | 08:14 PM
It's not quick but you could call Wellcraft and ask them what came on the boat stock. Or stop by a Wellcraft dealer with your hull ID number and ask the parts dept to help you.
http://www.wellcraft.com/index.cfm?#/2/
SDFever is offline
Old 05-05-2009 | 09:05 PM
Is your motor running properly? Is the bottom clean on the boat, no growth?
Start with the basics before assumming its the wrong prop, It should be close to what is needed.
Texaswater is offline
Old 05-05-2009 | 09:14 PM
I had a 83 Nova and I think I ran a 21P, it's been about 12 years so i cant be sure, try a 21 or 23 mirage
Pete280 is offline
Old 05-05-2009 | 09:45 PM
Try a 19" Mirage plus. I doubt the boat is going to be rocket out of the hole unless you go to something like a Merc High Five prop in a 17"
Griff is offline
Old 05-05-2009 | 10:10 PM
Yep 21P 3 blade, put a set of stainless marine headers on it, with a highrise manifold and a 850 rodchester, you will see 60plus mph, and can run your 19P 4 blade
26 REDLINE is offline
