Help 1996 7.4 mpi efi bogs off the line
has all new cap rotor plugs wires and still bogs when i hit the throttle it bogs can anyone help me with this , thanks james
carb
has the carb been cleaned or rebuilt recently??? may want to look there
I'm with 21, it sounds like an accelerator pump. Remove the air cleaner and check that fuel is coming out of the squirters on top.
Could be water in the gas (ethanol)?????????
MPI check fuel rail pressure
how to check fuel rail pressure ?
how can i check the pressure pz
after it bogs,,,,does it clear up and run good on top end,,,or does it keep bogding down all thur the rpm range:eek:
It Clears Up After It Bogs
yes it runs fine after it bogs
check all vacuum hoses for leaks,,,,other possible thing to look into,,,,map sensor,,,,tps sensor,,,,fuel pressure regulator
| All times are GMT -5. The time now is 03:41 PM. |
