-   -   500 EFI Problem (https://www.offshoreonly.com/forums/general-boating-discussion/209389-500-efi-problem.html)
gnorthga 05-22-2009 09:06 PM
500 EFI Problem
I have twins Starbard motor after running one minute I lose fire and the motor cuts off
BOAT HAS MSD BOXS AND DISTRIBUTORS AND # 2 MSD LARGE BLUE COILS
Changed coils no difference
you wait about 3 to 5 minutes and the motor starts up and does the same thing
any advice
onpointe 05-22-2009 10:23 PM
easy one
sounds like the msd box.... easy test....switch the boxes and see if the other motor cuts off....you could do the same with the coils.....its SO NICE to have twins.....good luck!!
onpointe 05-22-2009 10:25 PM
ive had SO MANY problems with msd stuff.... i drag raced for many years, all i will use is mallory intermetent problems blow
gnorthga 05-22-2009 10:37 PM
already switched coils no difference going to try boes in morning what about the pic up and module inside the msd distributor
onpointe 05-23-2009 12:17 AM
new one
Not so sure about the pickup...it is a possibility, as it does tell the coil to fire, but I've never personally heard of an intermitent problem with those... The fact that it starts back up and repeats says computer control mod inside msd box...
satisfied1 05-23-2009 01:33 AM
Try to wiggle the pink wire that comes off the Dist. to the coil . We just had to replace ours on the 42.
mike tkach 05-23-2009 10:01 AM
i agree,sounds like a bad box,but the pickup is cheap and easy to replace.i would change it anyway,then you eliminate the question of it being bad.
gnorthga 05-23-2009 10:20 PM
Thanks Guys It Was The Msd Box Up And Running 100+ For The Holiday
Oso Members Come Thru Again
onpointe 05-23-2009 11:07 PM
I hate to talk bad about a product, but over the years I've ran into WAY TOO MANY funny little problems with msd products. I'm talking problems that stump GOOD mechanics.. Mallory or for most cars atleast, the stock stuff supports around 500 hp.
gnorthga 05-24-2009 08:20 AM
Sounds like a winter project I might just have to look into
DrewDown 05-25-2009 03:18 PM
I had the same problem. It was the alternator wire. It was poorly routed. Rubbed through the wire protection, grounding out and shutting the motor off.
