Originally Posted by Raylar
(Post 2872786)
At Raylar Engine we like to use Shell Rotella 15-40W for breakins, got a great zinc and additive ashless wear package and after breakin you can switch to synthetics. I also like the gallon bottles, pouring 10 quarts from quart bottles just sucks!
Best Regards, Ray @ Raylar We DID break the cams in at 1600 RPM for 40 minutes as well..... |
(Post 2872786)
Best Regards, Ray @ Raylar The last 3 rebuilds I have used the cheap Napa straight 40 for break in, its only in there maybe about 1 hour, 5 dyno pulls or until I put a good load on it to seat the rings.Rob:drink: |
What about break in on a NEW long block? Rotella still OK? What about a straight HD40?
I would use the Rotella and change it and the filter between 5 and 10 hours. Also carefully cut open the filter that is removed and spread the pleated media inside and look for debris, especially iron, steel and aluminum particles. If there is a lot, check the oil filter again within a couple of hours of use and make sure the debris stops.
Best Regards, Ray @ Raylar |
Thanks for the responses.
Morry |
| All times are GMT -5. The time now is 05:55 PM. |
