HP500 timing
Old 06-11-2009 | 03:25 PM
Default HP500 timing
does anybody know the corect way to set the timing on a 1997 hp500 carb , with stock merathode ? thanks
tim brown is offline
Old 06-12-2009 | 07:28 PM
Ttt
Old 06-12-2009 | 11:29 PM
c_deezy's Avatar
I'm thinking it was 32 degrees at 3200 rpm, but I can't remember right off hand and I can't find my book at the moment either.
c_deezy is offline
Old 06-13-2009 | 12:31 AM
here is a link that will help you, also if you go up to the top to the right corner and look for search write in timing and you will find other good info for you to help make sure you fell like you are doing it right. Good luck with it.http://www.offshoreonly.com/forums/g...ghlight=timing
Boat Tech is offline
