ethanol question
Old 07-20-2009 | 12:54 PM
Default ethanol question
doing some reading on another board and got a bit disturbed by what I was hearing about the effect of ethanol on engines. I found this info about additives online but it does not look like the additives are really for duke. what do you guys recommend to keep an engine in one piece given todays fuels. thanks.
1996 carbureted merc. small block. stock as a rock with 145 hours on the meter.
plastic1 is offline
Old 07-20-2009 | 01:09 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Ethanol does suck, but as long as you manage your fuel well, as in don't leave it sitting in the tank forever, and keep it treated with additive, you will be fine. I've been using this since I was forced to get Ethanol, and all good so far. It's available at WalMart and just about any boat store.
http://mystarbrite.com/startron//con...3/123/lang,en/
Sydwayz is offline
Old 07-20-2009 | 01:34 PM
fastedy's Avatar
Dynoed, 10 more HP but had to go up 2 Jet Sizes front and rear to keep the same raito
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 07-20-2009 | 01:48 PM
Originally Posted by Sydwayz
Ethanol does such, but as long as you manage your fuel well, as in don't leave it sitting in the tank forever, and keep it treated with additive, you will be fine. I've been using this since I was forced to get Ethanol, and all good so far. It's available at WalMart and just about any boat store.
Brian, thanks for the suggestion. that product looks like one of the better ones tested and with no alcohol.
plastic1 is offline
Old 07-20-2009 | 06:58 PM
dreamboater's Avatar
Brian were you having problems before you started using this? Any idea if this product will deter the issues ethanol has on fiberglass tanks??
dreamboater is offline
Old 07-20-2009 | 07:57 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That I don't know Wayne. I don't know that there is any solution for you short of bladders. I did have a fuel issue. I got fuel in the Keys that I did not know contained Ethanol. It sat in the tanks for a few months with no treatment, and upon first firing ruined two fuel pumps, two fuel/water separators, and two inline filters in moments.
Sydwayz is offline
Old 07-21-2009 | 12:40 AM
No!!
offshoresteve is offline
Old 07-21-2009 | 01:12 AM
I've used the Startron many times over the last few years. It's worked great for me. I recommend it as well.
Darrell.
DMOORE is offline
