Oil Temp What's to hot?
Old 08-07-2009 | 10:45 AM
2112's Avatar
Originally Posted by johnnyboatman
My 557s Blown Get To 260 If Ran Hard, Been Trying To Get Them Back Down To 230 It Has The Large Teague Coolers.
+1 but I am doing it with N/A motors. I am starting to suspect I need a design change with the Teague coolers. Maybe a 4 Pass instead of 2? Even though they are the biggest coolers available, maybe even bigger is the key.
I am also checking into venting the raw water at the strainer to get the air out.
2112 is offline
Old 08-07-2009 | 10:51 AM
bcfountain's Avatar
Registered User
Default oil temp
i have been told that if the oil temp never gets above 212,then the water /moisture never boils off.the guy at merc said between 200-250 is ok.just my 2cents.my fountain runs around 230-240.
bcfountain is offline
Old 08-07-2009 | 11:18 AM
Originally Posted by Racerngr1
That might be a little too hot. I would recommend a bigger oil cooler. My boat (Fountain) has never gone above 180* at WOT, (500 EFI). What oil are you running?
That is not hot enough. You have to get the oil to at least 212*F to burn off condensation. An oil thermostat should be in your future.
Mine will get up to 250-260* after a long WOT pass.
Philm is offline
Old 08-07-2009 | 11:28 AM
Hydrocruiser's Avatar
Arrow
A heavier oil runs hotter due to more friction...I have used Amsoil Marine 15W-40 and it's a great 40wt product.
Hydrocruiser is offline
Old 08-07-2009 | 11:33 AM
I have heard statements regarding this multiple times, and here is what I think regarding that. Water boils at 212*F water does not need it to be 212* to evaporate. At 180*, the water will evaporate in no time. A pool evaporates water at 80*. Now what happens when a drop of water hits the connecting rods which are going to be hotter then hell. Goodbye water drop.
Racerngr1 is offline
Old 08-07-2009 | 12:27 PM
I agree with that statement, but have to ask why the manufacturers make oil thermostats designed to keep the oil above 212* then?
Water will evaporate much faster when it is boiling than when it is just hot.
Philm is offline
Old 08-07-2009 | 12:40 PM
Running 50wt may try 20-50 to reduce temp.
bonecrusher is offline
Old 08-07-2009 | 01:38 PM
I agree with you that water will boil much faster at a higher temp. I have no idea why the oil thermostats are designed to keep the oil thermostats above 212*. It would be interesting to see if you can monitor that with the merc computer while a engine is running.
Old 08-07-2009 | 02:05 PM
Rookie's Avatar
+1
Ice cubes evaporate in you freezer
Rookie is offline
Old 08-07-2009 | 02:50 PM
Just seems like everything that I read about oil temps says that an engine should always maintain AT LEAST 190* oil temps, and if a 212* thermostat is not installed, the engine should be run hard enough for enough time to get the oil temps up to over 212* in order to burn off condensation. maybe some experts will chime in and let us know what the deal is.
If this isnt necessary, I can sure save a lot of gas by not running 5000rpm all the time and cruise all day at 4200rpm with 180* oil temps.
Philm is offline
