Stepped vs Deep V
You should take a look at the Renegades also. These boats are built well and rigged well. Handle the ocean well also. Great people to deal with. You have a choice of stepped or non stepped hulls and they will sea trial you in both. Latest model is a 38 Footer, You will also have quite a bit of coin leftover versus the contender to put in your fuel tank.
Thanks Laud
I can tell you from experiance that a 30' boat with two big heavy 4 stroke's hanging off the back will be a single purpose boat , it might be fast, but the trade off is not worth it , make the company build it first and run it in all types of water before you committ , because once you own it , it,s yours !!!
RHC
RHC
Not to beat a dead horse, but I have a few questions regarding stepped hulls and was hoping the offshore racers might be able to offer a different perspective from my fishing forum.
I have the option of a stepped hull on a 31 foot CC offshore fishing boat or a conventional V. I fish off the coast of South Carolina, and usually encounter 3 foot seas. I run to the gulf, approx 50 miles each way, and want a faster ride.
The advantages of a stepped hull, as I am told, are faster ride and increased fuel efficiency at cruising speed. The V hull tops out at 65 mph with twin 350 Yahama 4 stroke outboards. The stepped hull, I am told, can do the same with twin 250 Yamaha 4 stroke outboards. They are on hull number 3 of the stepped hull, and have yet to power one with twin 350 Yamahas.
So what are the compromises, if any, of a stepped hull? How different is the ride? Are they hard to handle? Do they track well? How about slow speed handling (no wake zones might compare to trolling in the ocean).? Are stepped hulls better in lakes versus ocean? Do they spin end over end if I turn the wheel after hitting a wave?
Thank you,
Jason
Thank you,
Jason
