-   -   Quick help about oil (https://www.offshoreonly.com/forums/general-boating-discussion/216707-quick-help-about-oil.html)
Want Speed 09-12-2009 04:16 PM
Does anyone have any idea on where the dipstick should be to check oil on a chevy 468? Also where the oil fill should be? Thanks
Want Speed 09-12-2009 06:48 PM
Ok. Well there is a belt driven pulley that has a metal container with a cap tgat has a very short dip stick on it. Would this be the oil? It has a Carmel colored metal smelling liquid in it. Thanks
It wouldn't be drive fluid would it?
Want Speed 09-12-2009 06:50 PM
Also what weight oil? 5w-30? It's a 468ci
Want Speed 09-12-2009 09:26 PM
Here is a pic of what I am talking about the belt driven metal container with the cap with the small dipstick in it is circled in red. PLEASE let me know. Thank You
http://i79.photobucket.com/albums/j1...03/OilPump.jpg
Want Speed 09-12-2009 09:27 PM
and No the large Dayco hoses do not go into that thing as it looks it has a smaller tube that looks to run down under the engine...
Want Speed 09-12-2009 10:01 PM
Does no one know? I am going boating tomm and need to know. Thanks
Scott B 09-12-2009 10:04 PM
Thats the power steering pump..
Want Speed 09-12-2009 10:10 PM
OK Thanks! So do you have any idea on where the Dip stick for the oil is?
GoCiggie31 09-12-2009 10:20 PM
on my bbc it is on the other side of the engine(on the opposite side of the p.s.pump) between the water/separator filter for the fuel and the valve cover.
GoCiggie31 09-12-2009 10:23 PM
check this site for mercruiser recommendations:
http://www.mercurymarine.com/service...qs/fueloil.php
or
personally I use Mobil v-twin but there are other similar products that may work well IE AMSOIL, Joe Gibbs Racing etc...
Want Speed 09-12-2009 10:41 PM
I got some Quaker State 15W-40 just to get me threw the next couple outings.. When I get it winterized I will have them put in Merc Oil.
Want Speed 09-12-2009 11:35 PM
I checked both sides... but the Gil headers leave no room between the headers and valve covers on either side... This engine has a Holley Electric fuel pump (its carbuerated) and I followed the lines from the pump to the carb and I didnt see it ...
Any other ideas on a way to find this damn dipstick? Thanks
I'CE 09-12-2009 11:49 PM
W.S. get a mirror and look down below the Gill exhaust ck.both sides for a tube runnin out of the oil pans that should end with the dip stick on top. also you usually put the oil into the engine thru the valve covers, but you are just kidding. :circle:
I'CE 09-12-2009 11:51 PM
ps post some more pics . On the pic u posted on the starboard side of the engine u have a breather remove it and u can fill the engine with oil there BUT do not over fill it YOU must find the oil guage other wise known as the oil dip stick :eek:
Want Speed 09-13-2009 08:52 AM
http://i79.photobucket.com/albums/j1...3/IMG_0153.jpg
There was a screw cap that came out of the hole... Is this where the oil goes? Just use a funnel and start pouring right? then wait a few minutes and check on dipstick. then keep going till its in correct range correct
BTW I found the dipstick... Under the port side header pointed towards Bow of boat...
Want Speed 09-13-2009 09:25 AM
Come on guys... I know this is an EASY question... Someone help I am trying to get out to the lake today.
kjm5125 09-13-2009 09:34 AM
If that's the Valve cover, that's where the oil goes.
Yes
I'CE 09-13-2009 03:10 PM
w.s. we need more ?'s
