Like Tree0Likes
Hooking a boat
Old 04-05-2002, 06:34 PM
EX20's Avatar
My Boats: 2000 Wellcraft Excalibur
Default Hooking a boat
I have heard of the situation of when a boat hooks, and it does not sound fun. I have an idea of what happens, but can someone explain in some detail what goes on, and how to avoid it!
And any experiences?
EX20 is offline
Old 04-05-2002, 07:14 PM
rick32
Great Question !
Rick 32
Old 04-05-2002, 07:29 PM
IDRPSTF's Avatar
My Boats: Whatever you missed your payment on
Its alot like ground looping an airplane if you've ever done that. Im sure there will be some good repleys and stories to this one. Ive only done it once in a hard turn in the chop and the boat forgot that the bow goes in front. Fairly violent.
IDRPSTF is offline
Old 04-05-2002, 08:43 PM
David's Avatar
My Boats: 1981 Sunkisst Tunnel
I thought only "tail-dragger" pilots did ground loops! Full right rudder!
David is offline
Old 04-05-2002, 10:50 PM
ScreaminDemon
when a boat is running through the waves, it typically blows the wave apart and runs slightly through it and over it at the same time. Of course, the boat design and weight affect this greatly. if the boat hooks, it is when the water tells the boat which direction the water wants the boat to go...if the wave is "quartering" and the boat has a "blunt" entry and the speed and timing is right, the boat will hit the wave, but the hull does not go through, instead, it curves with the wave and assumes a new position...depending on speed and attitude.
just my .02!
Old 04-05-2002, 11:34 PM
Risk Taker's Avatar
Question
Is hooking more or less prevalent with stepped hulls
Risk Taker is offline
Old 04-05-2002, 11:35 PM
My Boats: 2004 PANTERA SURVIVOR
screamindemon is close. what actually happens is usally driver error in wich most cases cannot be corrected. when the boat comes out of the water most people don't have a feel for what direction the drives are going. when the boat lands on an angle the boat will bow steer a continue on in the direction the drives were pointed upon re entry. as long as you and your passengers can hang on then you can steer out of it and continue on. usally gets your blood pumpin real good and gets rid of any hangover you may of had. also leading cause of not getting laid that night if you had your wife in the boat.
Treadwell
Treadwellmotorsports is offline
Old 04-05-2002, 11:51 PM
DJD
My Boats: 38' Cigarette, 42'Post, Driver:F2-07 Wild Child
Quote:
Treadwell [/B]
LMAO!!!
DJD is offline
Old 04-05-2002, 11:53 PM
Bill272's Avatar
My Boats: 95 Formula 336, HP500's
Note to self: Do not hook the boat....
Bill272 is offline
Old 04-05-2002, 11:58 PM
wilerty
This should give you a good explanation of what it's like:
http://www.freezeframevideo.net/Video/video3.htm
http://www.freezeframevideo.net/Video/videoClip6.htm
http://www.freezeframevideo.net/Video/videoClip8.htm
Strip Poker 388
10-22-2007 06:30 AM
waterboy222
08-24-2007 02:24 PM
Dr. Phil
6
07-28-2007 05:51 PM
myscarab30
1
04-17-2006 11:29 PM
CN24
4
06-02-2005 09:33 PM
