Wy do spectre's hop.
A few factors I have found, Improper center of gravity, Wrong lift charecter prop, Center step placement needs adjustment( I have done this) Spray rails also need adjustment. And the deck of the canopy models hop worse because the air doesnt stall on deck properly and no low psi is not created midship back. This affects the angle of attack on the bottom. Many cats can hop but if you know where to look and fix you can get it out. Lots of folks like to cruise at 60-75 and the hop is in that zone.
Here we go again. The Motion/Spectre although similar in design, 2 points in front and square in the rear is not a Skater. Wider tunnel, wider running surfaces, different compression ratio, longer, staggered strakes....and have pics of a wooden plug somewhere.
Two Points in the front !! Yes I like and keep construction pictures myself.
