-   -   LH vs RH drive? Why single engine has LH drive? (https://www.offshoreonly.com/forums/general-boating-discussion/218077-lh-vs-rh-drive-why-single-engine-has-lh-drive.html)
KSims1868 10-05-2009 02:42 PM
I'm definitely not what you folks would call boat-savvy...but isn't a RH drive the "normal" drive for a single engine boat?
Why would a single-engine boat have a LH drive?
Or am I backwards in my thinking?
Smitty 10-05-2009 02:51 PM
The only boats I know of with a single that use left hand rotation is Fountain and Profile.
KSims1868 10-05-2009 03:04 PM
The boat I'm going to look at tomorrow (Tues) is setup for a single-engine bbc and has a left-hand TRS drive.
It's an older hull (1980), but I don't know what year the TRS is.
Magicfloat 10-05-2009 03:15 PM
Formula uses LH on their 271. Testing showed slightly better handling and minor top end gain. I have no idea why. No big deal either way.
fountainracing65 10-05-2009 03:21 PM
Bow lift. so they say.
BrettM 10-05-2009 03:25 PM
I have seen a few 27-29 Fountains with a LH prop on single, one Baja 275, and just this week a Cobalt 220. All with single BBC and Bravo 1 LH.
ActiveFun 10-05-2009 03:27 PM
Running it left hand helps counter the torque of the motor which sometimes makes the boat lean to one side when running.
bcfountain 10-05-2009 03:42 PM
south-paw
almost every 27-29 fountain w/single engine i have seen has a lhprop.reggie says they are faster .dont know why though.
TampaBeach 10-05-2009 05:05 PM
Having owned a 1998 27 fever LH set up and a 2001 27 fever rh set up. The difference on a 27 Fever is the lh, the boat in mid range is level and: with a rh it lists to port (bad). Now I was told a RH set up is a little stronger, would make sense my RH set up came with a 500efi. Other than trying to counter motor torq I cannot think of a logical reason.
Biggus 10-05-2009 05:22 PM
The left hand TRS is stronger than the right hand due to the placement of the lower drive gear.
