Can I just drop a blower on my 540's????
must of been tall decks 10.2 alum heads, 8.75 to 1 cmp. you could get 600 to 650 hp out of those talk to Dean Gellner.
There are charts that show static compression and how much boost you can apply safely with cast heads and pump gas. Usually a total compression of around 12:1 would be max. This is around 4-5psi for your engine. So you could do it safely but would not be able to turn up the boost too high. Wieand has the charts on the holley website. FYI - the aluminum heads would let you put a little more boost to it, 12.5-13:1 safely. So you don't have to run aluminum but it is a good hedge against detonation.
just found out my cr is 8.8 to 1 and was a gen 5 or 6 502 to start, and is now a 540. I was told to run a 871 or bigger with an intercooler to keep the air cool, and only like 4 pounds of boost and it should live...........what do yall think???
you need a intercooler also, my motor 572 will be 8.4 to 1 cooler with alum heads 1071 shooting for 1050hp plus, call Dean Gellner
[QUOTE=302Sport;3027086]just found out my cr is 8.8 to 1 and was a gen 5 or 6 502 to start, and is now a 540. I was told to run a 871 or bigger with an intercooler to keep the air cool, and only like 4 pounds of boost and it should live...........what do yall think???[/QUOTE
To start off with a Blower motor is a Blower motor and a n/a
motor is a n/a motor from the start of your plans to build.
I find this thread interesting because that is exactly what Im into now.
First off you must remove the cranks and have a 1/4 key added 180 away from your 3 1/6 key for the blower hub. If not the pull on the small factory key will brake and more than likely is will ruin the crank snoutt before you get it shut down.
7.4 to 8.4 is a good compression to look at doing. Reverse
domb(maby 20cc) blower piston and a H-BEAM RODS for sure. You dont need to spend a ton of money on the heads because the blower is going to make the power for the head.
Edelbrock makes a nice marine head for the money.The block will be fine. Your cam needs to be for a blower app. At the least your valve springs have to be set up for the compressed air comming from the upper side. The air speed is going to be charged and will put more weight on the top side of the valve. With this you may want to step up the spring rate. The fuel system will have to be completely changed. Boost referenced carbs is a must. The Ignition system has to have a boost retard. I like to drop 1.5 deg.
per pound of boost. If you dont do this you will kill your engines.
You will fall in love the first time out but they wont last long.
Here is my port engine. I was going to install blowers on the 502s and go. Just like you are wanting to do. And over $50,000 later in parts alone I have Dart 540 Blower Motors .
I hope this helps.
I hope this helps.
[QUOTE=tfarmer;3027570]
Sorry, That picture is my 502s Here is the new 540.
I hope this helps.
I hope this helps.
