Height of a big V on a trailer >
Old 11-02-2009 | 10:18 AM
RollWithIt's Avatar
You can always use the trick for getting rigs unstuck from overpasses. Let out some air from the tires dropping the height of the boat on the trailer. Just remember to re-inflate them once you are through the door.
RollWithIt is offline
Old 11-02-2009 | 10:32 AM
Using a draw bar on your truck that gets the tongue of the trailer as close to the ground as possible without dragging is a simple method for getting it in and out of the garage if you only need to pick up a few inches of room to clear the door.
BGIII is offline
Old 11-02-2009 | 02:20 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Originally Posted by BDARCHER
BT is over 10 ft.
"Excursion" gets his 43BT on a steel Myco under a 10' tall door. He lowered the (gravel) where the rear tires of the truck are traveling at the same time/distance the tallest part of the boat (windscreen) is passing under the door frame. It works well.
Sydwayz is offline
Old 11-02-2009 | 02:50 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
Not sure of Wal-Mart's door height, but this 47' wasn't gonna fit
WARPARTY36 is offline
Old 11-02-2009 | 06:29 PM
If you count the block courses on the building next to the door, it's 8'-0" tall.
bajario is offline
Old 11-02-2009 | 06:37 PM
I didn't know Wal-Mart changed oil in boats.
mcoutlaw is offline
Old 11-02-2009 | 06:50 PM
Bobthebuilder's Avatar
Hmm, think it may be more than that. 8ft should be 12 coarses. I get 14 coarses plus a part course at the bottom. Closer to 10ft but a few inches short of that, not that it really matters much.
Bob (thebuilder LOL )
Bobthebuilder is offline
Old 11-02-2009 | 07:26 PM
Jassman's Avatar
My garage is 12 x 52' has a 10 x 10' door no problem getting the Nortech in there. Sorry for the bad shots.
Attached Thumbnails Height of a big V on a trailer-643-apelahama-031.jpg   Height of a big V on a trailer-643-apelahama-034.jpg
Jassman is offline
Old 11-03-2009 | 04:35 PM
Bob- after recounting, I agree with your height accessment.
bajario is offline
Old 11-03-2009 | 06:54 PM
Thanks. That 47 Fountain sure sits high tho. Easy to think it was an 8ft door.
