700 sci fuel pressure problem >
Old 11-14-2009 | 10:09 PM
Default 700 sci fuel pressure problem
my port 700 motor stars losing fuel pressure after if has been running about 30minutes all the down to 20 on smart craft
anyone know the problem
gnorthga is offline
Old 11-14-2009 | 10:19 PM
try replacing your fuel filter
smithimports.com is offline
Old 11-15-2009 | 06:36 AM
the water seperator or the fuel filter at the fuel rail aeromotive type and why is it doing it only when the motor warms up
gnorthga is offline
Old 11-15-2009 | 08:03 AM
Had same problem in my 2007 42 fountain w700sci. Try looking at your fuel lines that come from your belly fuel tanks through the bulkhead to fuel switch valves. Mine had a slight cink in it and would reduce fuel pressure. So I ran a new line and it fixed my problem.
bbaur32 is offline
Old 11-15-2009 | 12:31 PM
Not the fuel line
Changed all fuel filters going for run
If still have problem going to switch to rear tanks and try running it again
gnorthga is offline
Old 11-15-2009 | 02:50 PM
OSO Does it again
Changed fuel filters
Last run 104.6
Fuel press perfect
Thank You OSO
gnorthga is offline
Old 12-19-2009 | 12:22 PM
aTX427's Avatar
Which filter did you change - the water / fuel separator that screws on below the pressure regulator on the front of the engine?
aTX427 is offline
