Heads for blower
Old 11-17-2009 | 08:09 PM
Default Heads for blower
Which heads would you guys recomend for a 509 with 5-7 pounds of boost, turning max rpm of 5600.
baja27 is offline
Old 11-18-2009 | 01:38 AM
Heads need to match the cam for the best performance. It really just depends on what you want and how much you want to spend.
Griff is offline
Old 11-18-2009 | 05:54 AM
PatriYacht's Avatar
Afr 315 Cnc
PatriYacht is offline
Old 11-18-2009 | 07:59 AM
Cams are 525efi
baja27 is offline
Old 11-18-2009 | 08:43 AM
Smitty's Avatar
Many choices out there, just make sure they are aluminum.
Best talk to Bob Madera of Marine Kinetics. He can spec heads and a cam that will make more power than you think.
Call Bob at 585-654-8583
Tell him Smitty sent you.
Smitty is offline
Old 11-18-2009 | 04:26 PM
Dart 380's
C5Steve is offline
Old 11-19-2009 | 02:11 AM
Originally Posted by C5Steve
Dart 380's
WAY TOO BIG.
The AFR's 315's would probably be a good choice.
Griff is offline
Old 11-19-2009 | 11:24 AM
I have the same set up. Bored 502efi, procharged at 7#, using the 525 cam and dart Pro1 320 mild port.
The combo dynoed 814+ @ 5500
That was with all the pumps belts and marine exhaust.
michigan troll is offline
