Installing trim tabs
Old 12-29-2009 | 09:50 AM
Your probably thinking of a Doweling Jig. You would need to come up with a way to attach it to the transom, maybe a suction cup?
alindquist is offline
Old 12-29-2009 | 03:39 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
On your drill jig, just use a couple of small wood screws in 2 of the holes to hold it in location, drill your remaining holes to size, then use them as your mounting bolts to then drill the 2 temp. screw holes to size.
I'd also seal your holes for the hoses and mounting bolts with resin to keep your transom dry.
US1 Fountain is offline
Old 12-29-2009 | 08:35 PM
I'd also seal your holes for the hoses and mounting bolts with resin to keep your transom dry.[/QUOTE]
I planned on - 3m 4200. Are you thinking something different?
capt2130 is offline
Old 01-03-2010 | 10:19 PM
fountain1fan's Avatar
I planned on - 3m 4200. Are you thinking something different?[/QUOTE]
3 m 5200 not 4200 robbie
fountain1fan is offline
Old 01-03-2010 | 11:35 PM
Ginger or Mary Ann?
Actually I was thinking to seal the raw exposed wood surface inside the holes with resin, and then using 4200/5200 for sealing the bolts and hoses in the holes.
Old 01-04-2010 | 06:47 AM
blue thunder's Avatar
This is what I did. Use a Q tip to get the resin in the holes. I also used 5200.
blue thunder is offline
Old 01-05-2010 | 07:43 PM
Anyone have anodes on their tabs? Do they need them?
capt2130 is offline
Old 01-06-2010 | 01:28 AM
FYI, 3M 4200 and 5200 are almost the same. The only difference is that 4200 has half of the adhesive strength. It will seal just as well below the water line. It will also be easier to remove the tabs, if needed.
Griff is offline
