will it blow or go!!!!!
Pistons are not the weak link!!!! All the comments above are dead on. Back it down to 5-6 lbs of boost and let it eat. Still should make 670 hp depending on cam. At 7 lbs you WILL push a headgasket.
I appreciate the input from everybody 5lbs it is. I run 93 octane, it is avaible on every other corner. I wasnt sure to rebuild a perfect running engine for 2 extra ilbs of boost or leave it alone and spend money elsewere
Im not sure what the deal is.
Its likely more market factor than anything else.
Performance Autos are are being mfgr'd to tolerate 91, and its cheaper for the oil companies to produce.
UD
