!!!help buying 24 ft jaws!!! >
Old 02-04-2010 | 08:00 AM
Default !!!help buying 24 ft jaws!!!
hey guys im buying a 24 ft jaws i really what to now if the trs drives are good becouse it comes with a 454 4 bolt main and a trs drive, the boat needs work but thats the least of the problem my real good friend is the owner of jaws here in miami so thats not a issue, i just whant to kno more about the trs and so fourth, thank you
rodriguezraul27 is offline
Old 02-04-2010 | 08:13 AM
What year is the Jaws you want to buy. I own a 1980 24 ft. Jaws Super Sport with a Volve 280 Drive. "Old School Boat", 30 years old and runs great.
AB From Windsor is offline
Old 02-04-2010 | 08:16 AM
its a 81 motor runs and all but need to replace shifter cables and do a major tune up boats been sitting 4 a year or more but always turned on twice a month
Old 02-04-2010 | 08:21 AM
cigrocket's Avatar
Thumbs up
TRS drive for that setup...mild power should be bullet proof. TRS is fine for up to 500HP-550HP. I ran 675HP for 100 hours without a problem on my old mistress before Konrads. And that is on heavy twin appliacations. A single 24' no problem if properly maintained. I am sure others will chime in with the same info. I would not hesitate if the deal is right
cigrocket is offline
Old 02-04-2010 | 08:54 AM
There's more than enough drive there for that motor/boat.... hopefully the X is not to low but that can always be fixed. We have trs parts if you need and we're here in the 305
thedonz is offline
Old 02-04-2010 | 11:29 AM
thanks alot on the input guys. ima go check it out in a bit and start up the motor and all, thanks again
Old 02-04-2010 | 11:41 AM
That Trs is more than enough for that boat, post pics when you can.
lowblue320 is offline
Old 02-04-2010 | 01:38 PM
You forgot to mention why it run's great Andy !!! A little old school mixed with a little new. And yes it does run great , now why not show us what makes it run. I was more than a little inpressed when I first seen it. Jeff
Jeff P31 is offline
