pantera 28
Old 02-13-2010 | 01:08 PM
Default pantera 28
hey guys ive just bought a pantera 28 less power
what would you guys reccomend i use for power that isint going th break the bank with resonable speed
i have have a new 300cummins/mercruiser diesel and surface drive and was thinking of using that or i also have a 440yanmar diesel
let me know your oppinion and what speed you think i would get
cheers gerard
gerard is offline
Old 02-13-2010 | 01:23 PM
i forgot to mention that i intend to keep the boat as light as possible ie no cabin interior stereo systems im going to try and lighten the boat as much as possible
cheers gerard
gerard is offline
Old 02-13-2010 | 02:25 PM
I don't know if I'd use the surface drive. Pantera 28's need bow lift, at least in the single engine pleasure version.
For reference, a newer pleasure 28 runs about 70mph. My 1996 ran 67-68 with around 550hp.
Griff is offline
Old 02-13-2010 | 03:16 PM
Stormrider's Avatar
JC Performance Engines
Well, a diesel will not be the lightest engine... for sure.
Where do you boat, or where are you from?
Got pics of the boat?
What are you looking to do with the boat?
Stormrider is offline
Old 02-13-2010 | 05:24 PM
im from ireland
im will be using the boat for inshore racing only and the only rule is that it must be diesel
the mercruiser 300 weighs in at 420kgs 700lbs of torque 3900rpm
and the yanmar 440 weighs 500 kgs 1200lbs of torque 3500rpm
i know a bravo one will work on the merc but with the yanmar i dont have much of a choice with that amount of torque
i dont have any pics yet as i dont have the boat home yet but i will post a few pics when i recieve the boat
cheers ill look forward to your comments
gerard
gerard is offline
Old 02-13-2010 | 06:10 PM
Originally Posted by gerard
im from ireland
gerard
i would go with the yamar you will need as much power as you can get to move that boat . as far as weight go's if it's a single you should be fine becuase they put 2 big blocks in them that way alot more then a single deisal ,
Drive, if you can get the drive all the way down on the transom would be the best, you mite also need some rocker plates to help with bow lift but you never know maybe not ,with the weight of that motor in the stern of the boat i would think you mite get the bow lift . but keep that drive as low as possable . i think they make a " drop box " that help bring the drive down some ,
call pepe or jo at pantera they would be more then happy to talk with you about the boat .
good luck
mike
mikebrls is offline
Old 02-13-2010 | 06:25 PM
cheers buddy i will give them a call on monday and see what they think
gerard is offline
Old 02-13-2010 | 11:13 PM
rchevelle71's Avatar
Diesel ouboards
rchevelle71 is offline
Old 02-13-2010 | 11:32 PM
The cummins sounds better to me because their is a lot of aftermarket performace parts for these engine's.
PURPLE HORNET is offline
Old 02-13-2010 | 11:55 PM
Steve 1's Avatar
Cummings has a nice package that would work fine a QSC 350 hp engine and drive
Steve 1 is offline
