what to do?????
1 Attachment(s)
How bad is this??
more>>>>>>
1 Attachment(s)
what about this? Any suggestions? POS merc risers leaked
Flushem
I would never buy cast merc mani's again.. Bite the bullet and get some GILs or something.
Interesting dilemma
So how many hours or seasons should one expect out of the factory merc manifolds on a BBC.
fresh water only? Salt but flushed religously? Salt and lazy about flushing? |
fresh water only, 3 seasons, stored indoors, heated warehouse.
My biggest concern is damage to motor. Will do compression check and leakdown. The worst rust was beneath cyl 3 as it is inline with opening in riser. The risers only have about 3/32" sealing area on the inside between the water ports and the exhaust port. Piss poor design IMHO. This is reminiscent of the space shuttle's solid rocket booster "field joint" that catastrophically failed. Looking at CMI's. |
Oilit
Id soak that valve stem and the top of the cylinder with mystery oil to help it free up the rust..Worse than rust if you ran it with water in the cylinder you might have damaged the wrist pin or rod bearing from hydraulic lock ..Good luck
| All times are GMT -5. The time now is 02:39 PM. |
