OK..Whats next in outdrives after Bravo1 >
Old 03-16-2010, 12:20 PM
Received 1,821 Likes on 907 Posts
With 800hp you are going to need more than a standard XR.
Griff is offline
Old 03-16-2010, 12:48 PM
hotlavey's Avatar
I have an HP500, 3.3 Whipple, AFR heads, and a XZ with an IMCO shortie drive that has lasted for 3+ seasons. I assume I am close to or a little over 800hp as my 2750 Lavey runs a tick under 100gps on fresh water. If you drive your boat with a little care your drive will last- an XR is much stronger then a XZ.
hotlavey is offline
Old 03-16-2010, 02:26 PM
Rik
arneson-industries.com
Offshoreonly Advertiser
Rik's Avatar
Arnesons. When you get tired of breaking things and paying the piper give me a call. Speed increase with reliability what more can one ask for.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 03-16-2010, 02:32 PM
Chris
CB-BLR's Avatar
IMCO SCX drive.
Possibly with a SC lower depending on application.
Much stronger than a Bravo or XR, and will bolt up in place of a X or XR with just a helmet change.
Chris
CB-BLR is offline
Old 03-16-2010, 03:26 PM
Registered User
Anyone running the IMCO SC drive? Looks like XR internals with heavier housing and bearings. You wouldnt need to change out the helmet and can keep your digital trim and captains call exhaust.
russellhorn is offline
Old 03-16-2010, 04:24 PM
Back4More's Avatar
Did you get my PM?
Back4More is offline
Old 03-16-2010, 04:35 PM
get a drive with a tranny, a wet sump 6 would be a great reliable drive.
kvschoolboard is offline
Old 03-16-2010, 04:38 PM
Max Machine Works out of Lake Havasu makes a killer drive (bravo style) that has been proven at over 800hp.
x7734x is offline
Old 03-16-2010, 04:47 PM
RIPSTA Racing Team
fireboatpilot's Avatar
Go with the Imco's. Is the Konrad available without using a trans? How much your willing to spend has alot to do with it and how much work are you willing to do as well. Some of these suggestions will require the use of transmissions and moving the engines forward to accomadate them. There's also the added expence of purchasing trans and fabbing mounts etc. I'd say that the Imcos are one step stronger than the XR's before getting into hugh dollars. I'm making a little over 700hp and just don't hammer it out of the hole which won't work anyway because it will just smoke the props. Have to watch the re-entry rpm's too. Just my 2cts worth.
fireboatpilot is offline
Old 03-16-2010, 05:08 PM
Imco sounds like a good way to try. I think they even advertise on OSO? I have emailed Arneson, and Konrad but I don't know much about either of them. I am just looking for a combination that will work. I have gotten used to being easy on the Bravo of the last year or so and it's done a good job, but I know whats comin now that the engine is done. At least I only have to buy 1
Scarab Billy is offline
