Nothing to hide - Ilmor opens the door on my 725/Indy buildup >
Old 03-26-2010 | 11:51 AM
  #51
glassdave's Avatar
Neno the mind boggler
Originally Posted by C_Spray
. . . . . so there are no holes to patch when you're done. . . . .
thats a plus
08 OPA High Points Champion
glassdave is offline
Old 03-26-2010 | 03:17 PM
  #52
Originally Posted by CB-BLR
Wow,
The attention to detail is definately a step above anything else on the market. I really like the Ilmore stuff... too bad they do not yet offer anything in the higher horsepower market.
Chris
Baby steps, I'm sure they have something brewing in development. Besides not sure this would be the best economy to introduce a new powerplant that more than likely won't be considered a production boat option but more so the high roller poker runners choice! Of course Merc introduced theirs we'll have to wait & see how many make it out there. My guees mostly dealer spec boats.
NASCAT is offline
Old 03-30-2010 | 02:06 PM
  #53
C_Spray's Avatar
Diamond Member #001
Well, while I'm waiting for the dyno backlog to clear out, things are moving on.
Since the engine will be mounted about 4" higher than before, the headers will require some "lumps" in the engine cover for clearance. The stylized NACA ducts will disappear completely.
Since the original engine covers are of cored Kevlar/epoxy construction and fully painted, I didn't want to hack them up. I called Rex Jardine at Vector Powerboats, and it turns out that they still have a set of molds to make original "Mannerfelt"-style hatches. For a very reasonable price, they laid up a set of hatches with just the outer skins; no coring or inner skins. These will serve as the basis for a one-piece hatch, and make life much simpler than having to strip and cut up the original ones.
Still (as always), this process is inevitably going to involve more of the dreaded fiberglass dust...
Attached Thumbnails Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100330_hatches.jpg
C_Spray is offline
Old 04-01-2010 | 12:26 PM
  #54
C_Spray's Avatar
Diamond Member #001
Since it's pretty much standard practice for the tabs to match the drive(s), I had mine painted. Ilmor was kind enough to supply me with the proper paint code, so in return, I machined the logo of a certain competing marine components manufacturer off of the planes....
Attached Thumbnails Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100401_tabbases-large-.jpg   Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100401_tabparts-large-.jpg
C_Spray is offline
Old 04-01-2010 | 02:52 PM
  #55
glassdave's Avatar
but you painted your motors Mercury Racing blue . . . . . .
Old 04-01-2010 | 03:06 PM
  #56
C_Spray's Avatar
Diamond Member #001
But you painted your motors Mercury Racing blue . . . . . .
Nope:
House Of Kolor TruBlue Shimrin Pearl. Much prettier!
C_Spray is offline
Old 04-04-2010 | 11:48 AM
  #57
Strip Poker 388's Avatar
Rob
nice package, interesting,thanks for sharing
rob
Strip Poker 388 is offline
Old 04-05-2010 | 06:51 AM
  #58
C_Spray's Avatar
Diamond Member #001
I needed some really small OD trim rings, since the tailpipe/mufflers are going to be 5" OD, so I made a set over the weekend. I've never really liked the traditional trim rings since they've always looked like just what they are: a stainless ring bolted on top of a rubber ring. These completely enclose the rubber ring. I'll use them both inside and outside.
Attached Thumbnails Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100402_ring1_lathe.jpg   Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100402_ring3_csink.jpg   Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100403_ring6_gasket.jpg
Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100404_ring8accents.jpg   Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100405_ring9gasket.jpg
C_Spray is offline
Old 04-06-2010 | 11:12 AM
  #59
C_Spray's Avatar
Diamond Member #001
The engine is off the dyno, and everything's being packed. IlmorDude has promised a video of the power run....
Attached Thumbnails Nothing to hide - Ilmor opens the door on my 725/Indy buildup-20100406_drive-large-.jpg
C_Spray is offline
Old 04-06-2010 | 07:08 PM
  #60
I have to put it thru the movie maker and tie a few clips together...................then its showtime!
ILMORdude is offline
