TRS outdrive part!!!
Old 04-10-2010 | 09:46 AM
Default TRS outdrive part!!!
I am looking for a part for my TRS outdrive and am not sure what it is called and was wondering if anyone knows where I can one.
It is located on the upper gear housing and the "sway bar" that the connects the 2 outdrives together. There is a hole at the top and the bottom and the "sway bar" is installed between the 2 holes and the bolt runs through the holes and attaches the sway bar. It is basically a flat piece with 4 ears on it (2) on each side. Only one side of this bracket is used per outdrive.
Sorry that I don't know what the name of the part is yet but I am investigating to get a part number.
Any help is greatly appreciated. Thanks in advance.
The Landlord is offline
Old 04-11-2010 | 04:03 PM
spazboz's Avatar
Correct me if I'm wrong, but I think you are looking for a wing-plate.
spazboz is offline
Old 04-11-2010 | 05:36 PM
Scott B's Avatar
Tie bar connects the drives. Do you need that, or the tie bar bracket that bolts to the drive? I have a couple of those floating around I think, no tie bars though..
Scott B is offline
Old 04-11-2010 | 10:51 PM
I am needing the tie bar bracket that bolts to the outdrives.
