Like Tree0Likes
Changing outdrive oil??
Old 04-27-2010, 10:19 AM
My Boats: 2007 Donzi 38ZR
Default Changing outdrive oil??
I have bravo one's with 502mpi's. I dont see the top fill/vent plug. I guess the drain is behind the prop. Any instructions for me, this is my first time,lol. How much oil does each drive take? Thanks alot
brian18330 is offline
Old 04-27-2010, 11:06 AM
Dave M's Avatar
My Boats: 2017 30 Concept, 300 Verados
Everything you need to know right here.....
http://www.sterndrives.com/changeyourbravogearlube.html
Dave M is offline
Old 04-27-2010, 11:21 AM
Thanks alot
Old 04-27-2010, 12:21 PM
Big Time's Avatar
On a side note, it takes a very long time for the oil to fully drain. Some even leave it overnight to fully drain. Bring lots of rags because you are likely to make a mess.
Big Time is offline
Old 04-27-2010, 12:29 PM
My Boats: Formula 303 SR-1
Quote:
Yup! And, you (brian 18330) have twins, so buy two oil drain pans so you can let them drain together, because it does take a loooooong time.
BowenCT is offline
Old 04-27-2010, 12:52 PM
Tantrum's Avatar
My Boats: Stray Cat Statement Marine
Try to do it after you run the boat and drives (oil) are still warm.
Look out for the thin cardboard gasket on the drain plug, they often stick to the drive and end up in the drain pan.
Merc racing makes them with o-rings which I prefer over the cardboard.
Tantrum is offline
Old 04-27-2010, 01:15 PM
anyone have the part number handy for the o-ring style?
vettex1 is offline
Old 04-27-2010, 04:41 PM
My Boats: 28 Daytona
Stick with the gasket type. Merc stopped installing the o-ring type a while back because they had problems with the vacuum from the propeller pulling gear lube past the o-ring.
BDMarine is offline
