Using a lifted truck to tow my 35 FT' >
Old 05-18-2010 | 10:02 PM
Catmando is offline
Old 05-18-2010 | 10:27 PM
If you build a truck right you will have no problem. When you go up in tires you need to change the gears. If it has the Banks programmer you can make changes to tow better. Like I stated before I tow only with lifted trucks and have never had an issue, but my trucks are set up right.
sonic69 is offline
Old 05-18-2010 | 10:37 PM
BattleCry's Avatar
You can buy a brand new truck from the dealer with an aftermarket lift on it. I don't see an insurance issue with it. Under that rationale, aftermarket wheels and tires would be a deniable reason.
As far as pulling with a lifted truck, it is a good idea to make sure that you have the correct hitch height for pulling.
BattleCry is offline
Old 05-18-2010 | 10:49 PM
Throttle Fever's Avatar
Just inspect your reciever hitch assembly. I had the front (where it mounts to frame) crack. 9" lift and 38's. Installed a Class 6 16000 lb reciever. Some class 5's are built pretty cheep. They also make a 20000 lb reciever, it has a 3" reciever instead of 2".
Throttle Fever is offline
Old 05-19-2010 | 07:14 AM
Originally Posted by Plowtownmissile
Yes you can but it puts more strain on your transmission. Owned this for a short time but I did pull with it a few times. 2002 F350 crewcab longbed Lariat diesel 4x4. 15inch suspension lift and 46" Mickey Thompson Baja Claws.
I bet that went through some diesel on the highway with a boat behind it.
Good looking truck though.
Wildman_grafix is offline
Old 05-19-2010 | 07:51 AM
I have 55K miles on mine and have towed my boats as far as 400 miles for poker runs with no issues. It has a 6" lift on 35s.
I did just add some super springs to the rear end to take care of the level issue. Not shown in this pic but man do they work good.
Attached Thumbnails Using a lifted truck to tow my 35 FT'-img00149-20100221-1014.jpg
Mykalvballer is offline
Old 05-19-2010 | 09:22 AM
DaleSC's Avatar
Originally Posted by rbr2328
What tires are you running?
Mich 395/85R20 46" w/ 12 inch lift.....
DaleSC is offline
Old 05-19-2010 | 08:38 PM
Went through two tanks a week if I daily drove it. Stock gears, no programmer, 5 inch stainless straight pipe that dumped, and the EGT always stayed cool. Never once had to use overdrive
Plowtownmissile is offline
Old 05-19-2010 | 08:45 PM
heres my new to me '06 3500 with 6" lift and 35's on it. Pulls like a dream and no problems what so ever!
debcod2 is offline
Old 05-20-2010 | 12:30 AM
I would sell the banks and get a mads smarty. The have the best tuner out there. I pull my 30 cat w/ 33's with the 170 hp tune and it does tend to heat up the egts but with a banks you are in no danger of making tooo much power.
kneeslider74 is offline
