Issue with my boat, please help >
Old 05-31-2010 | 05:17 PM
BURNSMAZZ's Avatar
I would call Brett.He will send you in the right direction.Depending on your x dimension that will make a big difference whether you should go with a 3 blade or 4 blade.Seems to me Checkmate was using some Hydromotive 4 blades with some sucess.
BURNSMAZZ is offline
Old 05-31-2010 | 05:26 PM
I have hydromotive 3 blade 24 pitch , that came off a checkmate like yours and ran very well 170.00 shipped.
3 blade well run faster than a 4 blade, but a 4 blade will come out off the hole faster, i might even trade props with you .we could work it out . hyd is stern lift prop, a bravo is bow lifter
fastscarab22 is offline
Old 05-31-2010 | 05:29 PM
chuckbeecher
From: Anywhere from the Laguna Madre to JAX and beyond
Originally Posted by BURNSMAZZ
Yes very capable of 65 mph.I would try a 23" mirage plus or call Bblades and talk to Brett about workin on that 25".How hard are you on the stick coming out of the hole.How does the prop look?Is it in good condition?There may be a problem with the prop.
I would do the above and call bblades any way to discuss it.
A Mercury Rev4 might do the trick.
He IS the prop man!!
chuckbeecher is offline
Old 06-02-2010 | 12:41 AM
I would call Brett at BBlades also. I would think that you have a 60-62mph boat with the right prop. My guess would be a 22 or 24 Bravo 4 blade. Maybe a REV4.
Griff is offline
Old 06-02-2010 | 11:18 AM
Actually i went with a hydromotive. I ordered a quad4 x 22p so we'll see how that works out. should work better all around then the mirage plus 25p
mustang3414 is offline
Old 06-02-2010 | 11:25 AM
Hydromotive will also let you(at least they used) exchange it once within like 14 days if you need a different pitch.
Griff is offline
Old 06-02-2010 | 11:42 AM
yes they will it's only $20 to exchange it and you have 30 days and if you dont want another they refund 90% at that point. I think the hdro prop should help alot?
Old 06-02-2010 | 02:15 PM
birdog's Avatar
Call the guys at Checkmate ?
birdog is offline
Old 08-03-2010 | 05:18 PM
Hey mustang why dont you ship the blade back i sent you , that you have had for 2 months and keep telling me you will send it , i sent it in good faith and know you are stiffing me.
STAY AWAY HE DOSNT DUE WHAT HE SAYS YOU HAVE MY PROP SEND IT BACK
