Issue with my boat, please help >
Old 05-31-2010 | 02:17 PM
Default Issue with my boat, please help
Well, I just bought a 2000 checkmate 259 convincor and took it out for the 1st time this week end. Its got the 502 magnum 415hp motor and a mirage 25p 3 blade prop. I was very disappointed in the performance. Everytime you take off and its starts to plane off the prop slips/cavitates and you have to back the throttle down then get back into it. secondly its only pulling about 4300rpm to. It seams very slow from a dead stop. Is this a problem with the prop? what do you guys recommend? any help
mustang3414 is offline
Old 05-31-2010 | 02:26 PM
Airpacker's Avatar
I would think a 25 is definately too much prop for the combo. A 23 at most and possibly even a 21 four blade might be the ticket.
PS, I wouldn't be doing too many hole shots with the thing either. Thats a heavy boat and if you hammer it out of the hole too often, its going to spit bravo parts at you.
Airpacker is offline
Old 05-31-2010 | 02:51 PM
Mine came with a 27p 3 blade cavitated like crazy and about 40 to 50 seconds to get on plan about 600hp tested 3 props all 4blades 26p 28p 30p went with 28p planes in about 15 seconds handles great over the 3 blade. If your near the ozarks I'll give you place I got test props from didnt cost a dime to test
firehawkcat is offline
Old 05-31-2010 | 03:03 PM
I'm by the chain of lakes in illinois. I'm not making 600hp, just the stock 415hp 502 magnum. Is it cavitating and only running 4300rpm because its too much prop?
Old 05-31-2010 | 03:34 PM
Pantera24's Avatar
What's your drive ratio? 1.65? I would try a bravo 1 22pitch
Pantera24 is offline
Old 05-31-2010 | 03:44 PM
is this boat capable of 65+mph with the right prop?
Old 05-31-2010 | 04:43 PM
BURNSMAZZ's Avatar
Yes very capable of 65 mph.I would try a 23" mirage plus or call Bblades and talk to Brett about workin on that 25".How hard are you on the stick coming out of the hole.How does the prop look?Is it in good condition?There may be a problem with the prop.
BURNSMAZZ is offline
Old 05-31-2010 | 04:50 PM
Prop looks great. i'm pretty hard on the throttle and steadily increase to full throttle. I'm thinking a good 4 blades may give me what I want. Its just an absolute dog from a stop or moving slowly. The bow comes up so high its ridiculous I think.
Old 05-31-2010 | 04:58 PM
Is the trim sender working? Are you sure the drive is all the way down when your coming out?
pq man is offline
Old 05-31-2010 | 05:04 PM
I checked that it moves all the way down and up.
