-   -   Vacuflush pump keeps running (https://www.offshoreonly.com/forums/general-boating-discussion/232627-vacuflush-pump-keeps-running.html)
PWRQUEST 06-14-2010 09:05 AM
I have a vacuflush toilet, and the pump does not shut off. When I put the boat in the water this year the pump would shut off but the cycle time for on and off was about 30 seconds, and now it keeps running... Would it be an air leak at the base of the toilet?
bill63 06-14-2010 09:14 AM
yep air leak in the system
jeff1000man 06-14-2010 09:16 AM
Mine does the same thing. Glad you guys figured it out.
PhantomChaos 06-14-2010 10:00 AM
Mine does the same thing. I had the pump checked and they said it was fine. So, there is a leak somewhere that is causing you to not make a vacuum so it will shut off. I hear there is a seal in the ball thingy that needs to be replaced?
Strip Poker 388 06-14-2010 01:01 PM
2 Attachment(s)
The pressure relief safety valve,the rubber flap valve thats in it will leak some times, it has the foam rubber stuff in the top. pore some water in there see if its sucks the water in,they also change to a better rubber grommet (white)a few years back.I got tired of replacing the valve ,I made a plug,pvc pipe with a cap,see pick.
Also, were the black plastic cover is ,the screw goes into the tank , can leak there, Under the cover the relay has a screw that is screwed into the tank.
Mine had a leak/crack in a mounting hole thats on the backside of the actual pump.I put 5200 on it.
you can use a solider iron on the screw hole, I put Velcro holding the cover on now.
also the seal at the potty flusher valve,usually leave a little water in the bowl will make it seal up when in use.
You can take cigarette and use the smoke off it,it will suck it in the tank,finding the leak.
Hope this helps
Rob
PWRQUEST 06-14-2010 05:37 PM
Hope this helps
Rob
I worked on it today. The pump shuts of now, for about 20 minutes i would guess. The spring loaded relief valve was sticking and leaking air out of it. How often should the pump kick on?
Thanks for the help.
Strip Poker 388 06-14-2010 08:38 PM
It should only run for a few minutes, also depend on how much waste is in it taking up area, It is not suppose to leak down any,and keep coming on. Mine still comes on,When I got a new valve it came with some grease to help seal it up,prob a silicone base,That safety valve can get trash,fiberglass dust etc in it and leak,thats the reason I plugged mine,they say dont because if the pump goes bad it can suck in the tank, I call BS .the pump only sucks 15inch pounds.
When you get sucked out I use to push in the safety valve to let in air, now I have to hold the flush valve open during pump out.
Also ck the outlet/dump hose up to the deck fitting,it should have a o ring also. the 90 that comes out of the tank has a duck valve in it ,it had a adaptor for the hose to fit on it, mine leaked there also.
goodluck
Rob:drink:
PWRQUEST 06-14-2010 09:52 PM
goodluck
Rob:drink:
Are you saying that after you took out the valve and pluged the hole you still have the pump kicking on?
:eek:My tank is in a hard spot to access, so if i had to replace the tank my buddy Tom would have a big smile on his face as he was cutting a very large access hole to put in a new tank.:evilb:
I am going to try the new valve first and maybe the boating gods will be kind to me and make the problem go away.
By any chance would you happen to have a part number for the valve?
Strip Poker 388 06-14-2010 10:38 PM
3 Attachment(s)
Originally Posted by PWRQUEST (Post 3136018)
Are you saying that after you took out the valve and plugged the hole you still have the pump kicking on?
Yes I still have a leak somewhere.
Take the foam out and put some water ontop of the valve or use the cig smoke see if its still leaking.you can see the grease were the screwdriver is holding the valve open.
I have a manual and parts list stuff i can fax ya if you want, phone # to the main parts guy for the VHT.
Theres rubber valves in thepump body also.When your pump cuts off does it flush OK, with plenty of sucksion
did ya ck the bowl valve? put some water see if it sucks thru
What year is yours?
PWRQUEST 06-15-2010 07:31 AM
What year is yours?
The boat is a 2002. The toilet flushes great. bowl valve, where is that? Yes I would like the guys number. Thanks for all your help...
