Technical Questions For Steve 1 >
Old 06-21-2010 | 04:57 PM
  #101
glassdave's Avatar
Neno the mind boggler
Originally Posted by Steve 1
Good Eye Dave, when I did the math models at 1200# VS the 15-18 degrees found in 5000# Hulls I came up with something a "little" different in deadrise also a byproduct of the radical bottom clean up was My stuff is able run in the rough and not beat up the crew.Look at a Cheetahcat run it does not create much of a disturbance at high speed everything is on the pads. the second boat I sent to Kuwait they were leading a very rough race and the boat trying to run second behind them crashed killing some people and the race was black flagged. the deadrise allows it to sink just enough in the wave crest to allow a straight path,If you are going up or down the boat is not going forward very fast.
On the M-11 Vid look at the beginning and watch it travel through the pack of M Boats.Watch the first 50 seconds for the cheetahcat then the pads and deadrise will be better explained.
http://www.youtube.com/watch?v=esxxt...eature=related
Drat they disabled my Chili Peppers Aeroplane
makes sense to me. I always thought using a delta pad can give you some speed but at the cost of a harsher ride. Buy coupling it with a steeper deadrise you can restore some of that, so theres is a balance between the two. This was something you found in the math beforehand? So through design you dont necessarily need a heavy boat to tame rough water.
Damn youtube police
08 OPA High Points Champion
glassdave is offline
Old 06-21-2010 | 05:49 PM
  #102
Steve 1's Avatar
Damn youtube police
Exactly and that engineered ride will not ever beat you ,The fishing boats also were very well mannered all the way from idle through "Boat" mode and into warp speed very predictable. LMAO it was a cool bit of background music.
Steve 1 is offline
Old 06-21-2010 | 08:59 PM
  #103
Steve 1's Avatar
Dave I will work on the music the next couple days.
Steve 1 is offline
Old 06-21-2010 | 09:42 PM
  #104
Eaton Photos's Avatar
Shoot'n Motion @ 1/80 Sec
Commercial Members
From a Technical standpoint, I honestly do not understand some of the key terms & phrases being used in this thread, but beyond those points, I've learned more from reading the past 10 pages, than I have read anywhere else online.
The knowledge & experiences that Steve has been sharing, is amazing.
James Eaton
www.eatonphotos.com
Eaton Photography on Facebook
Eaton Photos is offline
Old 06-21-2010 | 10:19 PM
  #105
Steve 1's Avatar
Sir stop me anytime and I will break it down a little further and I thank you for the nice comment.
Steve 1 is offline
Old 06-21-2010 | 10:44 PM
  #106
Steve, I cannot begin to tell you how much I am learning from this thread.
Thank you very much!
James
Apathetic is offline
Old 06-21-2010 | 10:47 PM
  #107
Steve 1's Avatar
James
I humbly thank you for the nice comments.
Steve 1 is offline
Old 06-21-2010 | 11:04 PM
  #108
What's a delta pad?
Mastercraft240 is offline
Old 06-21-2010 | 11:42 PM
  #109
Steve 1's Avatar
Originally Posted by mastercraft240
What's a delta pad?
Sir the pad would start narrow then widen at the transom, Kind of a triangle shape.
Steve 1 is offline
Old 06-22-2010 | 10:05 AM
  #110
Steve 1's Avatar
Dave here is the Pad on a old Cheetahcat 40.
Steve 1 is offline
