Oil spill in the gulf of Mexico >
Old 05-05-2010 | 10:58 PM
  #121
masher44's Avatar
Originally Posted by Steve_H
Want my address tough guy?
give me your lawyer too
masher44 is offline
Old 05-05-2010 | 11:54 PM
  #122
Originally Posted by WARPARTY36
and it was a rather impressive docking job.
I thought the backing job that Blee did getting out of that slip was even more impressive. I was just disappointed that Hot Boat Magazine had a picture of us arriving that day because if they had taken one when we left, I would have been behind the wheel.
E Dock DD is offline
Old 05-06-2010 | 12:36 AM
  #123
BLee's Avatar
Charter Mod
Haha, thanks for the compliment bro!
Having you around, is what keeps me sharp around the docks! My goal is always to have my boat consistently be the one that you don't have to worry with, while the chain is being assmbled.
Thanks for all of the MANY years you've helped in SO many fashions on these machines, Stan!
BLee is offline
Old 05-06-2010 | 05:20 AM
  #124
jayboat's Avatar
For those interested in a bit more of the technical side of this from industry folks, I found a good site call The Oil Drum.
From a commenter:
This well had been giving some problems all the way down and was a big discovery. Big pressure, 16ppg+ mud weight. They ran a long string of 7" production casing - not a liner, the confusion arising from the fact that all casing strings on a floating rig are run on drill pipe and hung off on the wellhead on the sea floor, like a "liner". They cemented this casing with lightweight cement containing nitrogen because they were having lost circulation in between the well kicking all the way down.
The calculations and the execution of this kind of a cement job are complex, in order that you neither let the well flow from too little hydrostatic pressure nor break it down and lose the fluid and cement from too much hydrostatic. But you gotta believe BP had 8 or 10 of their best double and triple checking everything.
On the outside of the top joint of casing is a seal assembly - "packoff" - that sets inside the subsea wellhead and seals. This was set and tested to 10,000 psi, OK. Remember they are doing all this from the surface 5,000 feet away. The technology is fascinating, like going to the moon or fishing out the Russian sub, or killing all the fires in Kuwait in 14 months instead of 5 years. We never have had an accident like this before so hubris, the folie d'grandeur, sort of takes over. BP were the leaders in all this stretching the envelope all over the world in deep water.
This was the end of the well until testing was to begin at a later time, so a temporary "bridge plug" was run in on drill pipe to set somewhere near the top of the well below 5,000 ft. This is the second barrier, you always have to have 2, and the casing was the first one. It is not know if this was actually set or not. At the same time they took the 16+ ppg mud out of the riser and replaced it with sea water so that they could pull the riser, lay it down, and move off.
When they did this, they of course took away all the hydrostatic on the well. But this was OK, normal, since the well was plugged both on the inside with the casing and on the outside with the tested packoff. But something turned loose all of a sudden, and the conventional wisdom would be the packoff on the outside of the casing.
Gas and oil rushed up the riser; there was little wind, and a gas cloud got all over the rig. When the main inductions of the engines got a whiff, they ran away and exploded. Blew them right off the rig. This set everything on fire. A similar explosion in the mud pit / mud pump room blew the mud pumps overboard. Another in the mud sack storage room, sited most unfortunately right next to the living quarters, took out all the interior walls where everyone was hanging out having - I am not making this up - a party to celebrate 7 years of accident free work on this rig. 7 BP bigwigs were there visiting from town.
In this sense they were lucky that the only ones lost were the 9 rig crew on the rig floor and 2 mud engineers down on the pits. The furniture and walls trapped some and broke some bones but they all managed to get in the lifeboats with assistance from the others.
The safety shut ins on the BOP were tripped but it is not clear why they did not work. This system has 4 way redundancy; 2 separate hydraulic systems and 2 separate electric systems should be able to operate any of the functions on the stack. They are tested every 14 days, all of them. (there is also a stab on the stack so that an ROV can plug in and operate it, but now it is too late because things are damaged).
The well is flowing through the BOP stack, probably around the outside of the 7" casing. As reported elsewhere, none of the "rams", those being the valves that are suppose to close around the drill pipe and / or shear it right in two and seal on the open hole, are sealing. Up the riser and out some holes in it where it is kinked. A little is coming out of the drill pipe too which is sticking out of the top of the riser and laid out on the ocean floor. The volumes as reported by the media are not correct but who knows exactly how much is coming?
2 relief wells will be drilled but it will take at least 60 days to kill it that way. There is a "deep sea intervention vessel" on the way, I don't know if that means a submarine or not, one would think this is too deep for subs, and it will have special cutting tools to try to cut off the very bottom of the riser on top of the BOP. The area is remarkably free from debris. The rig "Enterprise" is standing by with another BOP stack and a special connector to set down on top of the original one and then close. You saw this sort of thing in Red Adair movies and in Kuwait, a new stack dangling from a crane is just dropped down on the well after all the junk is removed. But that is not 5,000 ft underwater.
One unknown is if they get a new stack on it and close it, will the ***** broach around the outside of all the casing??
In order for a disaster of this magnitude to happen, more than one thing has to go wrong, or fail. First, a ****ty cement job. The wellhead packoff / seal assembly, while designed to hold the pressure, is just a backup. And finally, the ability to close the well in with the BOP somehow went away.
A bad deal for the industry, for sure. Forget about California and Florida. Normal operations in the Gulf will be overregulated like the N. Sea. And so on.
Roostertail does not lie.
NAPLES IMAGE Photo Galleries
jayboat is offline
Old 05-06-2010 | 07:24 AM
  #125
racer-x6's Avatar
I was once told a long time ago not to hijack someone else’s thread, let's try and keep this one about the oil spill and the effect it will have people's lives and our sport.
racer-x6 is offline
Old 05-06-2010 | 08:47 AM
  #126
jayboat's Avatar
From information is beautiful
jayboat is offline
Old 05-06-2010 | 10:19 AM
  #127
Charter Member #928
Wow! Haven't been on in a while but this is the OSO I remember. As for BLee, think he is a stand up guy, just like most of his friends I've met. So, he may be a member of the lucky sperm club. SO WHAT? No different then guys around my lake, friends, building 10000sq ft houses, while I'm trying to hold on to mine. So that defines them what kind of person they are? I don't think so. Jerks are jerks, good people are good people. Money only enhances the person you are. Guess that's why 70% of NBA or NFL people are broke after 5 yrs out of the league. People with money usually have other problems. Like, are these my true friends? All kinds of people trying to scam you. Or they run businesses which provide enough stress in life. And just because someone doesn't smile at you the first time doesn't define them either. We've all looked at people and formed some kind of opinion of them before we've even met them. Have a friend, 15yrs, blonde, 80's rock band hair. And that's the first thing people say is, what the hell is up with that. One of the best people I know and anyone who meets him agrees. As for the average person owning a cig, you can if they would let you run it 20 yrs on payments. But that's all changed with credit lending. I would never be able to buy what I have again new. Guess we may just have to agree to disagree. As for the slick, it sucks. But we have to push forward to cut ties with overseas supply since they don't like us anyway. Time to take care of ourselves. Guess had to put my 2 cents in since it's been a while. Dang, this is fun. lol
wigginout is offline
Old 05-06-2010 | 11:21 AM
  #128
From a commenter:
Jay great info ,thnx for posting
rhr 163.1 is offline
Old 05-06-2010 | 11:28 AM
  #129
88Fount33's Avatar
Beak botr
Time for a blow boat!
88Fount33 is offline
Old 05-06-2010 | 11:49 AM
  #130
JLAY's Avatar
Don't want to rain on your parade here but oil is used to make other products other than just gas. Propane, hexane, other "light" gases, diesel,fuel oil, asphalts, plastics, etc. Out of one barrel that may be the amount of gas in one instance, but it depends on what they are making money on at the time. If they are making more money on another product it may be less than the 19 gallons of gas, it may be more if they are making money on the gas.
JLAY is offline
