What wire to use???  Re-wiring some things in the engine compartment. >
Old 05-01-2002 | 08:35 PM
Waterfoul's Avatar
Gone Fishin'
Default What wire to use??? Re-wiring some things in the engine compartment.
Can you use regular copper wire? Or do you have to spend the long dollar and get tinned copper marine wire?? I need to re-wire the bilge pumps and a few minor things that run back there (stereo ground, power, etc...).
"Marine" wire aint cheap!!!!!!!
Thanks for the help!!
Mike
Waterfoul is offline
Old 05-01-2002 | 08:54 PM
Wildfire
All I have heard is "Use the tinned copper"
So, when you find the best place to buy from, let me know because all of my wiring went into the trashcan.
Old 05-01-2002 | 09:30 PM
Tinkerer's Avatar
Cool
Mike the tinned wire will hold up better than standard wire. It also has finer strands so it will stand up to vibration better. Do it right and buy the marine wire.
Tinkerer is offline
Old 05-01-2002 | 10:11 PM
C_Spray's Avatar
Diamond Member #001
Shop around for the best deal with BoatUS, West, BoatFix, etc. The two big names in the "good stuff" are Ancor (no "h") and Marinco. Forget bare copper - even in fresh water.
C_Spray is offline
Old 05-01-2002 | 10:23 PM
cartman
Yes you should use marine wire especially if you run in salt ,unless you like rewireing every few years.Trust me my bilge pump wires broke inside the insulation and I didn"t know it. The boat almost went down over a weekend when the bellows ripped and it rained.
Old 05-02-2002 | 12:01 AM
Audiofn's Avatar
Charter Member #232
Mike call me tomarrow. I have a special number to get you some wire cheap!!!!
Jon
Put your best foot forward!
Audiofn is offline
mcraymond3
04-04-2014 11:55 PM
danh63
Baja
7
02-26-2007 09:33 AM
FRMULTR
Eliminator
2
01-19-2007 10:34 AM
BWebb
2
04-29-2004 10:25 PM
Scott Morehead
Sonic
2
04-12-2004 08:45 PM
