Found metal 1 of my engines. Need help with id. >
Old 08-04-2010 | 02:12 PM
Fountain38SC's Avatar
Default Found metal 1 of my engines. Need help with id.
My port engine made a milk shake. The exhaust pressure tested ok. Pulled the intake manifold & found this in the lifter valley in the rear corner port corner. They're metallic, the 2 cricular pieces are rigid. I can bend the other pieces with very little pressure.
I'm stumped - anyone know what they are or where they came from???
Any & all help is greatly appreciated. thx.
Fountain38SC is offline
Old 08-04-2010 | 03:26 PM
Wobble's Avatar
SORE MEMBER
I'm thinking the circular pieces might be punch outs from the head gasket as they appear to 1/2" I'm just guessing though. The rest being flexible could also be a piece of head gasket
Wobble is offline
Old 08-04-2010 | 03:29 PM
Ted G's Avatar
The irregular pieces look like they may be bearing pieces-not good. It is possible the round ones are the oil filter bypass valve, not sure how it would get up top though.
www.cbpba.com
Ted G is offline
Old 08-04-2010 | 03:35 PM
Wobble's Avatar
SORE MEMBER
In any case a leakdown test will send you in the right direction
Wobble is offline
Old 08-04-2010 | 04:22 PM
BY U BOY's Avatar
double post
BY U BOY is offline
Old 08-04-2010 | 04:28 PM
BY U BOY's Avatar
I was thinking bering material. I had similar looking material in my engine when I tore it down last weekend and it was shavings from the piston(forged)
Good luck with it.
Attached Thumbnails Found metal 1 of my engines. Need help with id.-img00252.jpg
BY U BOY is offline
Old 08-04-2010 | 09:13 PM
Wobble's Avatar
SORE MEMBER
Good luck with it.
is that a broken lifter we are looking at? Sorry to hear about your bad luck Patrick
Wobble is offline
Old 08-04-2010 | 09:22 PM
Im saying lifter to.
whoya is offline
Old 08-04-2010 | 09:44 PM
BY U BOY's Avatar
nope those are the retro lifters when I went over to a roller cam..Shavings of 2 of my pistons when the crank broke and took out the rods, pistons and all.
Attached Thumbnails Found metal 1 of my engines. Need help with id.-crank.jpg   Found metal 1 of my engines. Need help with id.-crank2.jpg   Found metal 1 of my engines. Need help with id.-piston.jpg
BY U BOY is offline
Old 08-04-2010 | 09:47 PM
BY U BOY's Avatar
sorry for the high jack,now back to bidness
BY U BOY is offline
