Engine Install
Does anyone have a diagram of how the engine bolts into the transom?
I just bought all of the proper hardware but have never done it before so I am trying to figure out the order. Probably should have paid closer attention when I pulled the motor but it has been nearly 6mnths. It is an IMCO SC drive. Any help is appreciated. |
Standard bravo application using the two vertical bolts?
From bottom up - nut, transom mount flange, spring w/fiber washer, bellhousing flange, spacer, washer, bolt. |
Originally Posted by fantastixvoyage
(Post 3176005)
Tape up the washers so they don't fall off when your setting the engine on the transom assembly.
Originally Posted by TexomaPowerboater
(Post 3176397)
However, I usually lower the engine into place and slide the spring washer and fiber washer under the bell housing. |
| All times are GMT -5. The time now is 02:04 PM. |
