Outerlimits Fuel Tanks Leaching? >
Old 10-06-2010 | 05:54 PM
  #101
Jassman's Avatar
Originally Posted by 37ol
I have a 97 ol and I replaced 2 atl saddle tanks in engine compartment about a year and a half ago. I saw this thread and it got me thinking so I just called them. They asked what color they were, mine were a tannish color. They said they have a new material ,which is black, that holds up to these newer fuels. Was told that it is more rigid and could limit ease of replacement for certain applications. Was told that the 10% fuel will seperate when left in tank and cause a higher concentration at the bottom of the tank and ''could cause problems''. It was suggested that I drain the tanks for winter storage, just what I want to do..........
that also answers my original question, they were used as far back as 97. thanks
Jassman is offline
Old 10-06-2010 | 05:58 PM
  #102
OL40SVX's Avatar
Every Outerlimits doesnt have a fuel cell. There's alot more without than there are with.
OL40SVX is offline
Old 10-06-2010 | 06:09 PM
  #103
Audiofn's Avatar
Charter Member #232
Originally Posted by RunninHotRacing158
Cmon now Jass do you really expect every manu to redo all these affected tanks when they had no idea about Ethanol being added and what or when will they add to the fuel next .these tank redos are small price to pay compared to what we spend on these boats and part of maintenance .maybe Osama will do a stimulus package for this since its the phuckin ethanol thats causing it .
Unless the boat was made before 88 then Ethenol was starting to be used in Fuels and there should have been some knowledge that this was on its way.....
1988 was when Ethenol was started to be used to oxegenate fuel.
2003 is when California swapped over from MTBE to Ethenol along with a number of other states.
So any boat that was built after what 2004 or 5 should have know that Ethenol was going to be used. Now if you take a bladder that would last 4 years then there are a lot of bladders that are at the end of their usefull life. IMO this is going to get worse before it gets better for a lot of these manufacturers. Heck if your allum. tank goes bad the gas is going to soak into your hull and start to do god only knows what.
Put your best foot forward!
Audiofn is offline
Old 10-06-2010 | 06:14 PM
  #104
Jassman's Avatar
there are only just a few builders using these tanks.
Jassman is offline
Old 10-06-2010 | 06:23 PM
  #105
Audiofn's Avatar
Charter Member #232
Boats and other vehicals is what I was talking about.
Audiofn is offline
Old 10-06-2010 | 06:45 PM
  #106
pm203's Avatar
I don't know what the life expectancy is of a aluminum tank, but I really don't think it is of immediate concern.
pm203 is offline
Old 10-06-2010 | 06:49 PM
  #107
ActiveThunder's Avatar
Maybe answered already but.... Do the bladder tanks in question have baffles in them?
ActiveThunder is offline
Old 10-06-2010 | 07:42 PM
  #108
Audiofn's Avatar
Charter Member #232
I was talking about say a 80 Formula 302 or a 90 Tiger. There have been a ton of allum. tank failures over the years (not due to Ethenol). If that fuel gets out of the tank and up agains the glass I assume it would have the same bad effect of softening the glass and could cause a serious failure?
Audiofn is offline
Old 10-06-2010 | 07:50 PM
  #109
pm203's Avatar
Thought so.
pm203 is offline
