Outerlimits Fuel Tanks Leaching? >
Old 09-06-2010 | 04:16 PM
If i owned one of the above, it would be sitting in driveway, with all batteries removed and no shore power hooked up. we know what happens when we have fuel vapors and a ignition source. if that happens you will need to make only 2 phone calls, 911 and your insurance adjuster.
fkboatman is offline
Old 09-06-2010 | 04:31 PM
tgersx's Avatar
Originally Posted by whataride
So you are saying that a bladder replacement is different then changing a motor or drive ? Maybe the tank replacement you had completed was done incorrectly ?
As far as I know replacing a drive or an engine does not require cutting the hull or the floor, unless Outerlimits has provided an access hole or cover to remove tanks which would be great.
tgersx is offline
Old 09-07-2010 | 10:22 AM
No cover / access large enough to permit the Bladder removal . I am aware that a motor or drive does not require cutting the boat in some cases . I just disagree with the "never be the same " statement . Did you purchase a boat yet ? If you would like more info on the Tank issue PM . Me
whataride is offline
Old 09-07-2010 | 01:07 PM
pm203's Avatar
I have heard about this problem as well. Does anyone know the years/models affected?
pm203 is offline
Old 09-07-2010 | 01:15 PM
tgersx's Avatar
I shouldn't say that the boat would never be the same, I'm sure there are plenty of glass guys that can handle the job. My main concern is buying an expensive top of the boat and knowing that someone is going to have to cut it up to remove tanks bothers me to say the least. Also I'm just surprised that Outerlimits or an other manufactures that used those tanks didn't do a recall of some sort and fix the problem. If it was a car manufacture you bet there would be a recall. I'm also curious what other manufactures used these tanks and what years.
tgersx is offline
Old 09-07-2010 | 02:24 PM
pm203's Avatar
I shouldn't say that the boat would never be the same, I'm sure there are plenty of glass guys that can handle the job. .
Yah, but who wants to cut open a late model boat? I am not so sure the boat would be as good as new. It all depends who does the work and how detail oriented they are. As good as new isn't an automatic given.
pm203 is offline
Old 09-07-2010 | 03:18 PM
My 2001 42 does not have a fuel tank issue.
skater40 is offline
Old 09-07-2010 | 03:27 PM
I have a 2006 39 quattro it has serious issues with leeching
no smoking is offline
Old 09-07-2010 | 06:47 PM
Has OL offered any assistance ?
Old 09-07-2010 | 08:45 PM
LubeJobs42's Avatar
This is not a problem that is unique to Outerlimits. I have had 3 boats all less then 5 years old, all different makes that needed fuel tanks replaced. It sucks! It's expensive! But ATL is the company that made the tanks that MOST of the manufactures use to use.
LubeJobs42 is offline
