Outerlimits Fuel Tanks Leaching? >
Old 09-08-2010 | 05:45 PM
  #41
plumbers crack's Avatar
Talking
Did the tanks on my skater,no big deal. Pull the interior and replace the bladders or coat the tanks and re-glass. Factor in the cost of 6-10k and reduce your offer on the boat you want to buy.Because the tanks are leaking or may leak doesnt render the boat worthless.
Every boat manufacturer has had issues from tanks leaking to stringers and strakes falling off.It happens in every facet of life.
Suck it up.
plumbers crack is offline
Old 09-08-2010 | 06:20 PM
  #42
and when you pull the interior out and find out it cant be re-installed for a couple of reasons , ..so its not just the tank replacement .. Just had mine done ..2005 Quattro ... New tanks new upholstery .. And the manufactuers should be doing something to compensate for using a bladder that has a life span of 4 years with no access to remove and replace .
Still sucking it up and not liking it !
whataride is offline
Old 09-08-2010 | 06:24 PM
  #43
animalhouse's Avatar
Depending on the model it is not that big of a deal. It sounds worse than it really is, but worst case scenerio you have to pull the bolsters and cut the cockpit floor, but if done right, the section that comes out goes right back in, gets glassed and non skidded, and it is as good as new.
When the floor is cut out, a flange can be glassed in for the old section to sit on, and then you glass it smooth.
animalhouse is offline
Old 09-08-2010 | 07:45 PM
  #44
AIR TIME's Avatar
Originally Posted by animalhouse
there were ATL fuel bladders used in certain boats in 2005 & 2006
man I just priced out a 90gal bladder 2800 bucks, going to stick with aluminum a 3rd the cost.
AIR TIME is offline
Old 09-08-2010 | 08:38 PM
  #45
Lightbulb
My reply was for purchasing not current owners.Yes you have a right to be pissed as would I, if my boat was a few yrs old.I would think ATL the tank manufacturer would step up and promote itself a little better.I assume the bladders have no warranty and cant be liable for there product Failing?
Old 09-08-2010 | 08:47 PM
  #46
Jassman's Avatar
Fred, I take it Outerlimits is handling the repairs..???
Jassman is offline
Old 09-09-2010 | 09:16 AM
  #47
so all the 39' have this tank in 05 -06? since only a handfull were made..?
customryder is offline
Old 09-09-2010 | 09:23 AM
  #48
pm203's Avatar
There was also a 47 that had the problem. I also heard that the factory billet boat has the same issue.
pm203 is offline
Old 09-09-2010 | 09:33 AM
  #49
So what actually happens to the tanks? Do they come apart and leave goo in the fuel system?
Marginmn is offline
Old 09-09-2010 | 09:56 AM
  #50
pm203's Avatar
I'm not sure, but gas vapors enter the cockpit .
pm203 is offline
