Like Tree0Likes
10-71 Blower littlefeild
Old 09-15-2010, 10:19 AM
My Boats: 06 Eliminator Daytona 27'
Default 10-71 Blower littlefeild
Is there any info on these any where guys? Would like to see the guts of them. What oil to use? How to drain and fill it? I have a little oil leak on the back side. I am told there is only oil in the front and some grease on the gears on the back of the bolwer. It looks like the oil might be coming out where the blower meets the intake on the back side. If this is the case what is the easyest way to check this? Oil is getting pass the front seal back over the rotors and pushed out the back? If so is that front seal easy to change?
Thank you so much for any input!!!!
Matt
skydog is offline
Old 09-15-2010, 11:52 AM
Geronimo36
Panther's Avatar
My Boats: 36' Apache Warrior / 22' Apache Scout
Not a littlefield but here's my hampton's when I rebuilt them a few years ago.
Frank
10-71 Blower littlefeild-blowe-rebuild-2.jpg   10-71 Blower littlefeild-blower-rebuild-6.jpg   10-71 Blower littlefeild-blower-rebuild-3.jpg
10-71 Blower littlefeild-blower-rebuild-4.jpg   10-71 Blower littlefeild-blower-rebuild-5.jpg
Panther is offline
Old 09-15-2010, 11:53 AM
Geronimo36
Panther's Avatar
more
10-71 Blower littlefeild-blower-rebuild-7.jpg   10-71 Blower littlefeild-blower-rebuild-8.jpg   10-71 Blower littlefeild-blower-rebuild-9.jpg
10-71 Blower littlefeild-blower-rebuild-10.jpg   10-71 Blower littlefeild-blower-rebuild-11.jpg
Panther is offline
Old 09-15-2010, 12:04 PM
My Boats: 40 SKATER
Lee @ Littlefield will send you out the seals & gaskets
Old 09-15-2010, 12:29 PM
WOW Thank u guys that helps a ton!! I am going to put some dye in the blower oil and make sure thats what it is. And if it is i will get new seals and gaskets if bearings all feel good. Looks real simple.
Thank you Matt
skydog is offline
Old 09-15-2010, 01:25 PM
Brad Zastrow's Avatar
I am guessing it is not the grease you are losing. It probably is a leaking gasket at the base. Keep in mind the pressures of a supercharger will cause leaks. It will look like a oily residue when in fact it is gas. Kind of a brown color?
Brad Zastrow is offline
Old 09-15-2010, 01:29 PM
My Boats: 40 SKATER
Quote:
Thank you Matt
it is simple BIG Daddy ,and u can check the base gasket with some starting fluid and you'd have a vacuum leak.
good luck
Old 09-15-2010, 02:05 PM
Quote:
Yes it is brad looks and feels like brand new freash motor oil.
THANK YOU
skydog is offline
Old 09-15-2010, 02:07 PM
Quote:
good luck
Thank you i could just smoke test her too. Those bolts where the blower meets intake were on the lose side for sure i TQ them to 15LBS. Have not run after i did that!! Would by way sweet if it is gas.............
Skydog P.S. Kind of funny i only see this when i am hard on her making boooost!!
skydog is offline
Old 09-15-2010, 04:11 PM
Geronimo36
Panther's Avatar
Also, on my blowers, the end-caps don't "seal" to the case so it's possible some gas leaked between the rotor case and the rear cover.
Every time I pull a blower off an engine there will always be some old brown gas puddled up somewhere in the intake manifold cavity. Hopefully that's all it is.
Also, if/when you change the bearings on the rear cover ou can buy "sealed" bearings instead of having grease packed, that's what I did.
Panther is offline
