Fastest Skater with equal power?
I agree, my 36 Flatdeck hit 142 when I was running light with 850's and around 137 when full fuel and passengers. However, with all things being equal I think the 388 will probably be the fastest followed by the 368.
What did the 32 with Merc 850's run from the Miami boat show in '04 or '05?? Yellow boat, tested in PRA mag I believe.
I also read on here (for ref) that a 368 with Merc 600's/#6 drives ran 127, out east.
There was a 388 1075 boat at LOTO, that Blume semed to know.
I would think that the additional tunnel width & length of the 36 & 388 would make up for the weight disadvantage & then again layup comes into play. The results might also differ if you were comparing boats w/ 850's then compared the same 2 boats w/ 1000+ hp. There's obviously an minimum / optimum HP to weight ratio for each model & IMO once surpassed there maybe diminishing returns meaning the bigger HP will benefit the larger boats more than the smaller ones.
Like I said, I think all things being equal the 32 will be faster (in the proper conditions). With that said, obviously the bigger boats have a huge advantage once the conditions get rougher...
