1075 sci
So how long do they last? How long before top ends need to be done? How long before complete rebuilds ? Looking at a change and comes with 1075 sci with 52 hrs. 50 hrs are under 5000 rpm and would like to know where I stand in the big money maintenance time line.
I plan on getting 200 hours. I have a lot of idle time and don't hold it wide open.
Owners that buy new from the start don't care as much and usually run their stuff much harder.
After 50 hours its not uncommon to have the heads rebuilt, and a complete engine inspection performed. This may not be an oficial Mercury maintenence plan, but its a good way to help prevent a complete engine faiure in the future. I have seen a 1075sci blow at around 50 hours and also know people who have run into the 150 hour range before any real problems. As with any high perf motor change fluid and filters often, and I would recomend at 25 hour intervals.
That is what i thought . In my other big engines i have always done top ends at 75 hrs. With complete rebuilds at 150 hrs. Please keep the info coming if you own 1075 's and have other thought or experiences .
Agreed. Also find yourself a very good Hi-Performance Tech and use him. Around the 50 hour if you dont pull the heads have your tech pull the valve covers and check the rocker arm adjustment. Most failures start in the valve train. Regular oil and filter changes with recommended oils and you should be good. Fuel is also a big issue, make sure you buy good fuel at a reputable gas pump.
Good luck!!
With good maintaince, Oil changes, Valve lash checked regularly. Most guys are getting about 125hrs before needing top ends. Somewhere before 125hrs, I would have the lifters, springs, and timing belts changed. Your probably good for another 100+ hrs at that point. Theses motors have a very small cam, around .630 lift.
All the failures that I know of have been Lifters or Timing belts between 130-135 hrs. These were also very hard hrs run in open waters in Florida.
