Swing away trailer tongue…. >
Swing away trailer tongue?.
Old 11-02-2010 | 06:08 AM
Too Stroked's Avatar
I'll just give you the answer that I give most of our customers that ask if a given boat / trailer will fit in their garage. "If you back it in fast enough the first time..."
Too Stroked is offline
Old 11-02-2010 | 06:16 AM
Probably a stupid question Nate but are you trimming the outdrives down? Had to do that with mine when I kept it on the trailer. Dropped over a foot off of the overall lenght.
jmeng is offline
Old 11-02-2010 | 06:52 AM
SS930's Avatar
What type of construction is the existing trailer?
I'd look into making it so the tongue could be slid back and locked into position. Construct it much like the receiver for your truck hitch... just longer and with a couple of real beefy pins.
SS930 is offline
Old 11-02-2010 | 07:24 AM
I manufacture large renewable energy trailers (mild steel) that regularly exceed 10k lbs. We often build trailers with either removable or swinging tongues for security or space concerns. As someone stated earlier, properly engineered anything is possible. I would look into either a telescoping tongue or possibly a sleeved tongue that you could remove. Just remember, overbuilding is NOT engineering.
Jpzaluski is offline
Old 11-02-2010 | 08:17 AM
I have seen them on 34' boats, but it was a removeable tounge, it had to be bolted on and off, the dealer recomended you use an impact to tighten the six bolts. I think Ziemen out of Arizona made it.
the bear is offline
Old 11-02-2010 | 08:19 AM
Tom A.'s Avatar
I am in heavy highway construction and all of our message board trailers and many larger trailers have removable tongues for anti-theft. They are heavy duty steel square box sleeves with two pins holding them in. They work on the same principle as a truck hitch into a receiver where the sleeve supports the weight and the pins just keep it in place.
Tom A. is offline
Old 11-02-2010 | 09:53 AM
I saw this pic on another site and wasnt sure the purpose of this type of trailer.
ActiveFun is offline
Old 11-02-2010 | 11:06 AM
Yes, that's a very light duty version of what's being kicked around here.
Old 11-02-2010 | 12:04 PM
Hey Nate, I say try it see what happens.
topgun 38 is offline
Old 11-02-2010 | 01:20 PM
This is exactly what I was thinking. Everyone is saying it isn't going to be safe to have something fold away or removable but that is exactly what is on the back of all of our vehicles. the whole system rides on a single pin for most of us. so yes, it can be done, and it can't be that hard.
VetteLT193 is offline
