Alcohol Vs Gas
Old 11-05-2010 | 04:06 PM
rjr
Default Alcohol Vs Gas
I was just reading in a thread that the fastest boats run alcohol. We know that adding Ethanol to our gas makes it less efficient. Fewer MPG and I assume less power. So why do guys racing burn Alcohol? What do they do to their fuel systems that allows them to store Alcohol.
rjr is offline
Old 11-05-2010 | 05:11 PM
Alcohol does have less BTU's per unit than gasoline, but it doesnt detonate at high compressions like gasoline. With more compression you get more air/fuel in the combustion chamber, make more power. Plus alcohol and nitromethane require much less oxygen to burn per unit so you can pack much more fuel than air in as well, giving more power yet. Im not an expert so there Im sure there is more to it than that. Running straight alcohol requires a different carb setup since it needs to flow over twice the volume of fuel compared to gasoline, and as far as fuel systems go, if you are playing on that level, having a fuel system only last a couple years isnt the end of the world.
hotjava66 is offline
Old 11-05-2010 | 06:34 PM
SFOcean's Avatar
Charter Member #394
Methanol (wood alcohol) is used for racing, either pure or blended with nitromethane if you really want to get with the program. The alcohol in our gasoline is ethanol (grain alcohol). It (E85) can make more power than pure pump gas for the reasons outlined above, you do have to burn more though.
SFOcean is offline
Old 11-05-2010 | 06:48 PM
methonal is also much more tolerant to a rich mixture than gasoline.
phragle is offline
Old 11-05-2010 | 07:03 PM
It runs way cooler than gasoline...which equals more power. It is highly corrosive....and absorbs water like a sponge. You will not be able to keep it in your tank for long periods of time like gasoline, and your fuel system needs to basically be flushed with gas after using it. It also burns with little or no noticable flame. You wont be able to get it just anywhere (at the docks). As stated above..you need twice the amount as compared to gas...so, lets say you were going on an all day poker run, and figured you were gonna burn roughly 100 gallons of gas...youd need 200 gallons of alcohol on your boat. Not at all worth the trouble unless you have an all out race boat. Its actually a pain in the azz. There are far better ways to make power sir.
tinman565 is offline
Old 11-05-2010 | 08:31 PM
Wobble's Avatar
SORE MEMBER
I have tried both, generally speaking, alcohol tastes a lot better.
Wobble is offline
Old 11-05-2010 | 09:08 PM
Good point...lol.
Old 11-05-2010 | 10:41 PM
Just woundering if its still possible to get gas with out ethanol in it for boats or is it ok to run corner pump gas in 502s.
gofastrick is offline
Old 11-05-2010 | 11:13 PM
AIR TIME's Avatar
double the size of everything lines, jets haha, a friend is running it the new e85 or what ever they call it in a turbo big block 1800 to 2000hp motor for his boat.oh he does not plan on going on long trips just fast runs up and down the bay. I'll stick with gas with a lil additive
AIR TIME is offline
Old 11-05-2010 | 11:45 PM
Sir, reason i stopped you is because I can smell alcohol coming from your boat..
But officer its the boat drinking it not me, I swear!
HTRDLNCN is offline
