Fountain Lovers Do Not Open >
Old 11-19-2010 | 04:01 PM
  #31
I see...but it is more of a drive line thing. If its in the rules its in the rules.
Back4More is offline
Old 11-19-2010 | 09:49 PM
  #32
Hey.....you seen the spot price of gold lately??? Reggie has chain necklace needs that must be met. Then there's his barber.....that chit costs $$$$ man....gotta get wins to earn the scratch!
Ryan8886 is offline
Old 11-19-2010 | 10:01 PM
  #33
Expensive Date's Avatar
Do the rules specifically state no aluminum flywheels?Because I would not consider that part of a sealed engine.
Expensive Date is offline
Old 11-19-2010 | 10:29 PM
  #34
2010 Technical Rulebook 3/23/2010
1.12.2.
Certification and Sealing - To be eligible for competition in these classes, all individual engines of the approved type listed in paragraph 1.12. above, first must be certified and sealed prior to competition by an SBIP approved source in accordance with the then existing procedures established by SBIP, with the “approved” seals as supplied from SBIP. IT IS THE RACERS' RESPONSIBILITY TO HAVE THEIR ENGINE (S) INSPECTED AND SEALED BY an SBIP approved source. If for any reason a seal is broken or the engine must be “freshened” or repaired, the engine must be examined, repaired, serviced and re-certified by an SBIP approved source. Broken or missing seals will be grounds for disqualification and other penalties.
1.13.5.
Modifications and Changes - No modifications or changes of any type may be made to an engine, or any components thereon, including but not limited to the engine control modules or related internal codes, engine blocks, internal components, ignition systems, fuel systems, electrical systems, exhaust systems, valve systems, induction systems, lubrication systems, camshaft, crankshaft, heads, etc. unless performed by an SBIP approved source or approved in writing by SBIP.
Nothing about an aluminum flywheel unless it falls under "etc"....Maybe they should factory seal the flywheels then.
Old 11-20-2010 | 07:29 AM
  #35
Originally Posted by CigDaze
Or just write Fountain on your boat, and everything will be okay.
I guess I'm OK then
PARADISE ISLAND is offline
Old 11-20-2010 | 09:11 AM
  #36
glassdave's Avatar
Neno the mind boggler
1.12.2.
1.13.5.
Very clearly it is covered in 1.13.5. This is a major component capapable of enhancing the boats performance. We're not talking about swapping out lighter valve covers
08 OPA High Points Champion
glassdave is offline
Old 11-20-2010 | 09:31 AM
  #37
the link doesn't work what happens?
Maelstrom TG38 is offline
Old 11-20-2010 | 09:38 AM
  #38
Jolley's Avatar
Link is down...... Someone got their panties in a bundle probably ?
Jolley is offline
Old 11-20-2010 | 10:16 PM
  #39
As usual...I'm a day late and a dollar short....
Unfortunately, the link has been taken down...
I would have loved to have seen it...
Divenstar
divenstar is offline
Old 11-20-2010 | 10:32 PM
  #40
Cash Bar's Avatar
Mod Squad Enforcer
Bwahahahaha.
HOLY SHT, WE HAVE AN ALUMINUM FLYWHEEL.
I THINK THE WHOLE SARATOGA STAMPEDE BOAT WENT OUT THE BACK DOOR OF THE FACTORY
www.gregsellswaterfront.com
Cash Bar is offline
