use fogging oil or not??
Old 11-30-2010, 07:56 AM
i think it be a good idea to turn over the engines half way through the winter too. just a revolution or two. keep the rings from sticking. which is the main reason for fogging a motor in the first place. spark plugs should be changed in the spring after fogging anyway. not sure why you cant fog an efi engine though. interested in seeing someone post why.
panicrev is offline
Old 11-30-2010, 08:07 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
Originally Posted by Airpacker
And why is that?
It's in the Mercury books/manuals. It cakes on and can mess up the IAF/MAF sensors.
Merc recommendation is:
1) Dump 1/2 of fuel water separator out and fill with 2-stroke oil, re-install and winterize with this mixture.
OR
2) Run fuel line to fuel pump from small can of gasoline with 2-stroke oil premixed. (Look in the book for the ratio.)
It's discussed on here every year.
Sydwayz is offline
Old 11-30-2010, 08:58 AM
On the carb motors I have used ATF for years poor it right down the carb till it smokes out the exhaust
lightning jet is offline
Old 11-30-2010, 09:08 AM
There was an article in Teague on tech a couple of years ago. He reccomended that you used a garden sprayer with mavel mystery oil for the 525efi, 600/700 sci ect.
A.O. Razor is offline
Old 11-30-2010, 09:10 AM
wrinkleface's Avatar
Been do'n it like that the last few years in my 525's, no probs!!!I just put new filters on at winterization w/ the oil poured in!
wrinkleface is offline
Old 11-30-2010, 10:27 AM
Forum Regulator
Sydwayz's Avatar
I prefer to put the 2-stroke oil in the 1-season-old fuel/water separator (after close inspection for rust); and put new fuel/water separators on in the spring. I've had great luck with this method for going on 10 years.
First time this year, I winterized with a portable tank of non-ethanol fuel as well. I still have stabilized ethanol laced fuel in the tanks, but I'm going to pump that out into my daily driver over the winter.
Sydwayz is offline
Old 11-30-2010, 11:28 AM
Airpacker's Avatar
OR
Well, I beg to differ with Mercury on that.
IAT sensors can be cleaned with a shot of brake clean in about 5 minutes if necessary and there is NO (MAF) Mass Air Flow sensor on any Merc efi and chances of actually getting any foggin oil into the (MAP) Manifold Air Presure sensor are pretty dang remote. Better chance of gumming up the injectors with oil doing it Mercurys way IMHO and that comes from being in the auto business and servicing efi systems for almost 30 yrs now.
Airpacker is offline
Old 11-30-2010, 11:59 AM
that's what i was thinking, based on my 20 year auto experience...
panicrev is offline
Old 11-30-2010, 12:13 PM
Received 1,821 Likes on 907 Posts
Originally Posted by Audiofn
You don't keep them long enough to worry!
Pantera was 6 years and 275 hrs. Isn't that long enough?????
The AT has had 3 seasons and 150hrs and is not going anywhere soon.
I also use my boats often enough that keeping the cylinders coated with oil isn't an issue.......unlike some trailer queens
Griff is offline
Old 11-30-2010, 12:17 PM
Forum Regulator
Sydwayz's Avatar
Don't shoot the messenger guys. This has all been discussed here in the past.
Sydwayz is offline
